Running smartctl from shell causing hba timeouts
Turgin
I have 8 x 2TB SATA2 drives attached to an IBM BR10i (LSI 1068e). I also have 6 x 128GB SSDs attached to the LSI controller on my Supermicro X8DT6-F motherboard. Both HBAs are flashed with IT firmware.
New install of FreeNAS-9.10-STABLE-201605240427 (64fcd8e).
I am playing with running FreeNAS under ESXi 6 for an AIO home server. My FreeNAS guest has 32GB RAM (locked), 2 vCPU, and I have PCI passthrough configured for both HBAs. Everything seems to be working well except..
When I run smartctl -a on any of the 2TB drives from the shell option through the ESXi console I get the following errors:
mpt1: request 0xfffffe00009e1da8:2550 timed out for ccb 0xfffff8000b794800 (req->ccb 0xfffff8000b794800)
mpt1: attempting to abort req 0xfffffe00009e1da8:2550 function 0
mpt1: completing timedout/aborted req 0xfffffe00009e1da8:2550
mpt1: abort of req 0xfffffe00009e1da8:0 completed
mpt1: request 0xfffffe00009f3d08:2552 timed out for ccb 0xfffff8000b794800 (req->ccb 0xfffff8000b794800)
mpt1: attempting to abort req 0xfffffe00009f3d08:2552 function 0
mpt1: completing timedout/aborted req 0xfffffe00009f3d08:2552
mpt1: abort of req 0xfffffe00009f3d08:0 completed
I do not get them when running short or long tests nor do I get these errors when running the same commands from an ssh session (nothing in dmesg either) . I also do not get these errors on the SSDs from either console.
Should I be concerned? Any ideas why its happening?
Mirfster
Not sure, but from what I gather this is a pretty old card and cannot see drive space over 2.2 TB (like the PERC 6/I). May want to consider getting a more commonly recommended card (M1015, LSI 9211-8I, H200, etc..) and possibly kill two birds with one stone.
If your hearts set on sticking with those cards, then perhaps others will provide some insight.
Turgin
I'm not set on it necessarily , but I'm only using 2TB SATA2 drives on it so I thought it would be ok to use for now. The drives are not recognized by the Supermicro onboard LSI (but are by the onboard SATA) and I tried this so I could get 8 drives without having to get another card.
I fully intend to get an M1015 when I change out the drives for 4TB ones down the road.
If memory serves me right something isn't quite right with those cards when doing PCIe passthrough.
Even if I'm wrong, the best fix I see is to get an M1015 or equivalent.
Turgin
I was afraid of something like that.
Unfortunately, these 2TB drives aren't recognized by the onboard LSI 2008 and I suspect an add-on card with the same chipset would yield the same result. The drives were working pulls from a decommissioned NetApp filer and they have some "special" NetApp firmware which apparently interferes with them working on SAS2/SATA3 controllers for some reason. I even contacted Hitachi trying to get some updated firmware and they referred me to NetApp based on the serial number. I didn't pursue that any further.
For the moment, since this is still a sandbox for me, I'll just roll the dice unless someone can recommend a SATA2 HBA not based on the 1068e chipset to try.
Mirfster
Well, you can get a H200 for ~$55.00 (without cables) if you are so inclined. Not sure if it is going to cure your drives since you mentioned that they came from a NetApp. While I am not really versed in NetApp drives, I feel a bit leery about them especially if Hitachi pass you off to them... But would think that maybe/perhaps there is a way to wipe them...
Turgin
One would think...I couldn't convince the Hitachi support guy to give me any of the secret sauce. I tried the firmware for a "normal" DK7SAA200 drive and the flash utility wouldn't do it because it didn't like the firmware on the drive already. I may be trying too hard to make something work that is probably going to make me cry in the future.
Mirfster
Netapp stuff is basicallt proprietary and locked down. So yeah, you're really making a mistake trying to use anything that is Netapp hardware in anything that isn't a Netapp device. This issue is actually a selling point when people call iXsystems for a quote. ;)
Turgin
Fair enough. Since I am still testing and playing around they seem to work well enough. I won't trust them for any "real" data once I get to that point.
