Running old ver8 plugins
9C1 Newbee
I'd like to upgrade to the latest version 9.x of FreeNAS from 8.x. Unfortunately, ver 9 can't run all my ver 8 plugins. Specifically, LazyLibrarian. What I was thinking of doing is run 8.x for LazyLibrarian on a separate machine after I upgrade. Is there a better way to go about this?
Joshua Parker Ruehlig
the dobytang branch has been updated but it always errors when I test it. you can try it but you will encounter the same issue.
9C1 Newbee
I would just install it by hand on a jail in your 9.x machine or ask the dev to upgrade the plugin to 9.x.
Sent from my GT-I9300 using Tapatalk
Is there some sort of guide on how to do this? I have been searching and have come up with nothing.
Joshua, I was looking at a site with a few of your plugins. It looks like you made an XDA plugin for 9.x. I was told it also does books. Was it any good?
I think you mean XDM, haven't used it but I believe there is a working books plugin.
9C1 Newbee
You are correct, XDM. Horrible name. Not that Sabnzbd rolls off the tongue well either. Thank you.
What plugin are people using for books these days?
