TGM
 - May 22, 2017
I have a HPE ProLiant MicroServer Generation 8 (Gen8). I want to run FreeNAS from and SDCARD.
The storage configuration is as following:
1x SDCARD
4x HDD's (STORAGE)
I'm thinking of the following options.
1. Install /boot partition on SDCARD and /root on STORAGE in a ZVOL or DATASET, for example tank/os. I don't know if this is possible with FreeNAS or if it permits per device partioning.
2. Install FreeNAS on SDCARD completly and disable any write activities like logs or any other scheduled tasks that can shorten the SDCARD's life.
3. Install FreeNAS on SDCARD completly and load it to RAM, separatly loading the config files from tank/os.
Witch one of the above options is doable and easy to implement?
Thank you.
1x SDCARD
4x HDD's (STORAGE)
Thank you.
