I'm fairly new to Freenas and just upgraded to 9.3.
I just tried to setup an rsync task to copy my .system and samba config to a network drive for backup.
I no longer see the .system directory listed in my user pool as it was with 9.2 so I can't select it for the rsync task. Has it always been this way?
In the GUI it still shows the system dataset as being on my user pool, but if I do a "ls -a /mnt/UserPool"
the .system dir is not listed. With a little digging I found it is now mounted at "/var/db/system" which is not selectable as an rsync task.
Anyone know a way around this? Do I have to write a script and setup a cron job?
