pcubed
- May 10, 2021
Hi folks,
I'm trying to migrate an old FreeNAS 9.2 installation to the latest version of TrueNAS Core by moving the data via rsync. I initially noticed errors saying:
And so I looked around the forum and found this post which seemed suited to my use case (the two servers are both integrated into an AD via Samba and I want to keep all the ACLs). However, even after following the advice of desertrider, I'm getting the same errors but I've noticed that the files referenced don't actually exist according to the filename that rsync gives me. For example:
You'll notice the .gLGA9e extension on the file.
I'm using rsync over SSH as root (both sender and receiver) with the following command:
Any ideas what I'm missing ?
rsync: mkstemp "/mnt/Vol01/..." failed: Operation not permitted (1)
rsync: mkstemp "/mnt/Vol01/...MyDocument.doc.gLGA9e" failed: Operation not permitted (1)
MyDocument.doc exists but not MyDocument.doc.gLGA9e. For all of the thousands of files I want to sync, they all fail (except the directories, which are all created with the ACLS preserved it seems) but they all have a different weird extension at the end.I'm using rsync over SSH as root (both sender and receiver) with the following command:
[root@oldnas] /mnt/Vol01# rsync --partial --stats --progress -A -a -r -v --no-perms MyFolder root@newnas:/mnt/Vol01/
