Chris Jefferies
- Dec 6, 2015
I'm trying to backup my 3 pools to a single-disk pool so I can detach that pool and move it offsite but (from the log entry):
Running version: TrueNAS-12.0-U8.1
When I click on Run Now on any of the 3 tasks, it fails quickly with:
Thanks for any tips,
Chris.
@ERROR: chroot failed rsync error: error starting client-server protocol (code 5) at main.c(1671) [sender=3.1.3]
- I added a new 8tb disk to my server
- restarted the server
- the server recognized the disk
- ran smart test and quick wiped the disk
- created a new pool - back-pool
- added the disk to the pool
- added a vdev dir to the pool - mnt/back-pool/backup-2022 (I can see it when using the shell with the root:wheel user and group)
- I created some Rsync Modules in the rsync service, RW, enabled,
- I applied the rsync service to 3 Rsync Tasks, each is supposed to send a pool to backup-2022, localhost, PUSH, enabled
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 405, in __run_body
rv = await self.middleware.run_in_thread(self.method, *([self] + args))
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 979, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/rsync.py", line 712, in run
raise CallError(
middlewared.service_exception.CallError: [EFAULT] rsync command returned 5. Check logs for further information.Thanks for any tips,
Chris.
