I'm using TrueNAS Scale 22.02.0 and attempting to setup an rsync/ssh task. My issue is that the tasks reported a failure with an error code 23, partial file transfer. For one of my storage pools I corrected the issue by dropping to the shell and manually running a dry run rsync task, I discovered that I had a file name that was too long. However I'm having trouble getting that troubleshooting method to work on the other pool I'm trying to sync. I manually run the rsync command and get zero output (rsync -avn local remote) in the shell. But when I run the task in the GUI I still get a failure 23.
In the GUI I'm using the Times, Delete, Preserve Permission, Delay Updates flags.
Does anyone have suggestions for troubleshooting? This is a large video library with lots of subfolders so it may be filename/path related like my first sync job but I'm not sure how to determine that for sure.
