Hi there,
In order to increase the size of my pool I started replacing and resilvering drives.
My pool is a 4 disk raidz2 with WD30EFRX disks that I am now replacing with WD50EFRX disks.
The replace and resilver of the first disk took about 10 hours. The resilver of the second disk is now running for 12 hours and just finished 50%, so it is considerably slower. It started with comparable speed for the first hour then went down.
Should I be worried? Could this be just normal?
I have stopped all services (AFP, NFS, CIFS) before starting. Also did a scrub before. SMART is not showing errors, messages neither.
The pool has a capacity of 86% which isn't recommended, I know, therefore going to increase size.
Freenas is latest version (FreeNAS-9.3-STABLE-201501090144) with updates applied.
Disks are attached to an IT flashed IBM ServeRaid M1015.
Disks have been hot swapped.
System is running with this configuration now for about 6 months without any issues so far.
Here is the output of zpool status:
pool: zroot
state: DEGRADED
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Sun Jan 11 22:23:49 2015
4.99T scanned out of 9.42T at 123M/s, 10h28m to go
1.21T resilvered, 53.04% done
NAME STATE READ WRITE CKSUM
zroot DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/a8707053-9a75-11e3-9287-0050569e52b8 ONLINE 0 0 0
gptid/a8eebc4d-9a75-11e3-9287-0050569e52b8 ONLINE 0 0 0
replacing-2 OFFLINE 0 0 0
10221799220697409017 OFFLINE 0 0 0 was /dev/gptid/a96eb79b-9a75-11e3-9287-0050569e52b8
gptid/21825bf6-99d8-11e4-b972-0050569e3db2 ONLINE 0 0 0 (resilvering)
gptid/1b882e48-9984-11e4-b972-0050569e3db2 ONLINE 0 0 0
errors: No known data errors
