SOLVED Reporting database used size 2.67 GiB is larger than 1.01 GiB.
misaka
I'm running TrueNAS-SCALE-22.02.3 in pve, I have a raidz2 main zpool consisting of 4 16T drives (passthrough sata controller into TrueNAS), and a 50g ssd zpool for testing. 10G RAM, host CPU at j4125, working in host mode.
Today, after I started TrueNAS, I received warning "Reporting database used size 2.67 GiB is larger than 1.01 GiB.", After that, all my storage pools are offline and when I tried to start the nfs service it also failed. As well, the reporting page in WebUI does not show any data.
I tried to run
rm -rf /var/db/collectd/rrd/*
and reboot, then everything seems to be back to normal.
I would like to know if this is a bug or if I have some wrong settings? What should I do to avoid this from happening again
morganL
Captain Morgan
Administrator
I tried to run
How much RAM.. 10GB seems unusual?
morganL
Captain Morgan
Administrator
My host has 16G RAM and has allocated 10G to TrueNAS (balloon=0)
There was a previous bug that was similar that was fixed.. related to quotas on datasets.
If it reappears, its worth reporting.
misaka
I solved the problem before by rm -rf /var/db/collectd/rrd/*, but today, a week later, the problem reappeared. After I restarted my pve host, I saw the same warning in TrueNAS and lost contact with all my zpool. Also, there is another warning "New ZFS version or feature flags are available for pool main. Upgrading pools is a one-time process that can prevent rolling the system back to an earlier TrueNAS version. It is recommended to read the TrueNAS release notes and confirm you need the new ZFS feature flags before upgrading a pool.".
This bug only seems to appear when I start TrueNAS for the first time after starting pve, and when I restart TrueNAS, all my zpool comes back.
I have now switched to TrueNAS Core and I will test it for a while to see if the same problem occurs.
Trevor68
Getting the same message over and over here now too, running 22.02.04, is this fixed in Bluefin, maybe I should just upgrade?
misaka
Yes, it was fixed in the recent beta, but at the same time the new beta version still had a lot of various problems, and I finally migrated back to core
Trevor68
I fixed this by cleaning up the DB size, looking at the bluefin RC bugs I think I will wait for release to update.
Revamp
Hello All, I have this same issue.
It appeared after a shutdown and restart, I noted before I did that, that all the help "?" icons to all settings did not pop up the help dialogs hence the restart to see if this was the issue and then this occurred in the alerts..
Reporting database used size 2.65 GiB is larger than 1 GiB. (as per attached screenshot)​
I havent set my pool yet so It might be to do with the fact that its written to the Nvme that the OS is installed on..
I dont know any help would be appreciated?
Revamp
This is a fresh install 1 day old..
To add to the above none of my reporting systems are working, They are all (every section) just reporting a warnings of missing file and or directories. As per attached screen shot.
Don't know what to do here to fix it..
Any help would be very much apprciated..
TIA
Revamp
morganL
Captain Morgan
Administrator
I'd suggest setting up pool first and making sure it has system dataset.
There have been several reports of this error but no bugs found... its likely to be a misconfiguration.
Revamp
Ok Ill clean the drives individually first then go and do that..
Thanks for the feedback much appreciated.. :smile:
Revamp
Hello again,
So I have deleted all partitions on all 4 drives, restarted and now created a pool. Named it HDD pool..
Regards the above and that I'm on bluefin, I looked at the documentation on how the create a "system" dataset and couldn't find a coloration that matched the menu system. The only thing I have done is left the syslog server checked so it writes to the "system" dataset which I can't find anywhere unless it's under the bonnet.
I know how to create a dataset but this is the question how do I create a "system" dataset and assign it to or choose it to be used by the syslog system?
All I could find was the screenshot attached but as said before does not colorate to the menu system I have.
What to do for this final step would be much appreciated.
TIA
Revamp
morganL
Captain Morgan
Administrator
Hello again,
TIA
Revamp View attachment 70783
If there is one pool.. that is automaticaly selected for system dataset.
Revamp
Excellent..
Thank you very much for your input and time, the systems are up and running normally with all reports functioning again after the pool creation.. :smile:
