In "Replication Tasks" I choose a Periodic Snapshot Task. In its description it states:
Snapshot schedule for this replication task. Choose from previously configured Periodic Snapshot Tasks. This replication task must have the same Recursive and Exclude Child Datasets values as the chosen periodic snapshot task. Selecting a periodic snapshot schedule removes the Schedule field.
What does this mean? The Schedule field for the Replication Task isn't "removed" when I choose the Periodic Snapshot Task, nor is the one in the Periodic Snapshot Task so not sure which schedule it's going to use. I am assuming it used the "Periodic Snapshot Task" schedule and if so then what happens in the cycle? Does the Periodic Snapshot Task trigger the replication task when it's completed?
***** UPDATE
I ran some tests and if you setup a Replication Task that uses an associated snapshot, the Periodic Snapshot Task schedule will be used, so when that time comes and snapshot is taken and then replicated
			Help: Periodic Snapshot Tasks
***** UPDATE
