winnielinnie
- Oct 22, 2019
Can you import this pool on a different computer or try with CORE?
I can boot an Ubuntu Live ISO and import that way.Can you import this pool on a different computer or try with CORE?
$ cat /sys/module/zfs/version # TrueNAS-SCALE-22.02-RC.2 2.1.1-1 [yottabit@nas1 ~]$ sudo zpool get version vol1 NAME PROPERTY VALUE SOURCE vol1 version - default [yottabit@nas1 ~]$ sudo zpool get all vol1 | grep 'feature@' vol1 feature@async_destroy enabled local vol1 feature@empty_bpobj active local vol1 feature@lz4_compress active local vol1 feature@multi_vdev_crash_dump enabled local vol1 feature@spacemap_histogram active local vol1 feature@enabled_txg active local vol1 feature@hole_birth active local vol1 feature@extensible_dataset active local vol1 feature@embedded_data active local vol1 feature@bookmarks enabled local vol1 feature@filesystem_limits enabled local vol1 feature@large_blocks enabled local vol1 feature@large_dnode active local vol1 feature@sha512 enabled local vol1 feature@skein enabled local vol1 feature@edonr enabled local vol1 feature@userobj_accounting active local vol1 feature@encryption active local vol1 feature@project_quota active local vol1 feature@device_removal enabled local vol1 feature@obsolete_counts enabled local vol1 feature@zpool_checkpoint enabled local vol1 feature@spacemap_v2 active local vol1 feature@allocation_classes enabled local vol1 feature@resilver_defer enabled local vol1 feature@bookmark_v2 enabled local vol1 feature@redaction_bookmarks enabled local vol1 feature@redacted_datasets enabled local vol1 feature@bookmark_written enabled local vol1 feature@log_spacemap active local vol1 feature@livelist active local vol1 feature@device_rebuild enabled local vol1 feature@zstd_compress active local vol1 feature@draid enabled local
pamac install linux515-zfs
Ugh. Well I guess this may be more difficult than I had hoped. I'll grab the CORE ISO too, just in case.Looks like the latest version on Ubuntu Impish is ZFS 2.0.6.![]()
Manjaro has ZFS 2.1.1 in its repositories.Ugh. Well I guess this may be more difficult than I had hoped. I'll grab the CORE ISO too, just in case.
Fine, fine. I fetched that ISO too. LOL. Replication is about 90% finished... waiting with bated breath...Manjaro has ZFS 2.1.1 in its repositories.
Boot into live ISO, check the kernel version with uname -r, use pamac to grab linux515-zfs (assuming its kernel 5.15), and then modprobe zfs.
See my earlier post.
Replication Between Pools Causes Corruption
Can you import this pool on a different computer or try with CORE?www.truenas.com
$ grep ' ./.cshrc' /mnt/ssd_scratch/md5sum_orig.txt # Original dataset. eb4ea27bddb78d8caf944b9c0f76ccae ./.cshrc $ grep ' ./.cshrc' /mnt/ssd_scratch/md5sum_enc.txt # First destination dataset where corruption was first observed. 16da5f6ca9fb073a578996c538b3167c ./.cshrc $ md5sum /mnt/vol1/jacob.mcdonald_migrated/.cshrc # New destination dataset with the exactly same corruption. 16da5f6ca9fb073a578996c538b3167c /mnt/vol1/jacob.mcdonald_migrated/.cshrc
[yottabit@nas1 ~]$ hexdump /mnt/vol1/jacob.mcdonald/.zfs/snapshot/migration/.cshrc 0000000 2023 4624 6572 4265 4453 0a24 0a23 2023 0000010 632e 6873 6372 2d20 6320 6873 7220 7365 0000020 756f 6372 2065 6373 6972 7470 202c 6572 0000030 6461 6120 2074 6562 6967 6e6e 6e69 2067 0000040 666f 6520 6578 7563 6974 6e6f 6220 2079 0000050 6165 6863 7320 6568 6c6c 230a 230a 7320 0000060 6565 6120 736c 206f 7363 2868 2931 202c 0000070 6e65 6976 6f72 286e 2937 0a2e 2023 6f6d 0000080 6572 6520 6178 706d 656c 2073 7661 6961 0000090 616c 6c62 2065 7461 2f20 7375 2f72 6873 00000a0 7261 2f65 7865 6d61 6c70 7365 632f 6873 00000b0 0a2f 0a23 610a 696c 7361 6820 0909 6968 00000c0 7473 726f 2079 3532 610a 696c 7361 6a20 00000d0 0909 6f6a 7362 2d20 0a6c 6c61 6169 2073 00000e0 616c 6c09 2073 612d 0a46 6c61 6169 2073 00000f0 666c 6c09 2073 462d 0a41 6c61 6169 2073 0000100 6c6c 6c09 2073 6c2d 4641 0a0a 2023 6854 0000110 7365 2065 7261 2065 6f6e 6d72 6c61 796c 0000120 7320 7465 7420 7268 756f 6867 2f20 7465 0000130 2f63 6f6c 6967 2e6e 6f63 666e 202e 5920 0000140 756f 6d20 7961 6f20 6576 7272 6469 2065 0000150 6874 6d65 6820 7265 0a65 2023 6669 7720 0000160 6e61 6574 2e64 230a 7320 7465 7020 7461 0000170 2068 203d 2f28 6273 6e69 2f20 6962 206e 0000180 752f 7273 732f 6962 206e 752f 7273 622f 0000190 6e69 2f20 7375 2f72 6f6c 6163 2f6c 6273 00001a0 6e69 2f20 7375 2f72 6f6c 6163 2f6c 6962 00001b0 206e 4824 4d4f 2f45 6962 296e 230a 7320 00001c0 7465 6e65 0976 4c42 434f 534b 5a49 0945 00001d0 0a4b 2023 2041 6972 6867 6574 756f 2073 00001e0 6d75 7361 0a6b 2023 6d75 7361 206b 3232 00001f0 0a0a 6573 6574 766e 4509 4944 4f54 0952 0000200 6976 730a 7465 6e65 0976 4150 4547 0952 0000210 6f6d 6572 0a0a 6669 2820 3f24 7270 6d6f 0000220 7470 2029 6874 6e65 090a 2023 6e41 6920 0000230 746e 7265 6361 6974 6576 7320 6568 6c6c 0000240 2d20 202d 6573 2074 6f73 656d 7320 7574 0000250 6666 7520 0a70 7309 7465 7020 6f72 706d 0000260 2074 203d 2522 404e 6d25 253a 207e 2325 0000270 2220 090a 6573 2074 7270 6d6f 7470 6863 0000280 7261 2073 203d 2522 2223 0a0a 7309 7465 0000290 6620 6c69 6365 090a 6573 2074 6968 7473 00002a0 726f 2079 203d 3031 3030 090a 6573 2074 00002b0 6173 6576 6968 7473 3d20 2820 3031 3030 00002c0 6d20 7265 6567 0a29 7309 7465 6120 7475 00002d0 6c6f 7369 2074 203d 6d61 6962 7567 756f 00002e0 0a73 2309 5520 6573 6820 7369 6f74 7972 00002f0 7420 206f 6961 2064 7865 6170 736e 6f69 0000300 0a6e 7309 7465 6120 7475 656f 7078 6e61 0000310 0a64 7309 7465 6120 7475 726f 6865 7361 0000320 0a68 7309 7465 6d20 6961 206c 203d 2f28 0000330 6176 2f72 616d 6c69 242f 5355 5245 0a29 0000340 6909 2066 2028 3f24 6374 6873 2920 7420 0000350 6568 0a6e 0909 6962 646e 656b 2079 5e22 0000360 2257 6220 6361 776b 7261 2d64 6564 656c 0000370 6574 772d 726f 0a64 0909 6962 646e 656b 0000380 2079 6b2d 7520 2070 6968 7473 726f 2d79 0000390 6573 7261 6863 622d 6361 776b 7261 0a64 00003a0 0909 6962 646e 656b 2079 6b2d 6420 776f 00003b0 206e 6968 7473 726f 2d79 6573 7261 6863 00003c0 662d 726f 6177 6472 090a 6e65 6964 0a66 00003d0 650a 646e 6669 0a0a 6669 2820 2420 743f 00003e0 7363 2068 2029 6874 6e65 200a 2020 2020 00003f0 2020 6220 6e69 6b64 7965 2220 575e 2022 0000400 6162 6b63 6177 6472 642d 6c65 7465 2d65 0000410 6f77 6472 200a 2020 2020 2020 6220 6e69 0000420 6b64 7965 2d20 206b 7075 6820 7369 6f74 0000430 7972 732d 6165 6372 2d68 6162 6b63 6177 0000440 6472 200a 2020 2020 2020 6220 6e69 6b64 0000450 7965 2d20 206b 6f64 6e77 6820 7369 6f74 0000460 7972 732d 6165 6372 2d68 6f66 7772 7261 0000470 0a64 2020 2020 2020 2020 6962 646e 656b 0000480 2079 5c27 5b65 2748 2020 2020 6562 6967 0000490 6e6e 6e69 2d67 666f 6c2d 6e69 2065 2020 00004a0 2020 2320 6820 6d6f 0a65 2020 2020 2020 00004b0 2020 6962 646e 656b 2079 5c27 5b65 2746 00004c0 2020 2020 6e65 2d64 666f 6c2d 6e69 2065 00004d0 2020 2020 2020 2020 2020 2020 2020 2320 00004e0 6520 646e 200a 2020 2020 2020 6220 6e69 00004f0 6b64 7965 2720 655c 335b 277e 2020 6420 0000500 6c65 7465 2d65 6863 7261 2020 2020 2020 0000510 2020 2020 2020 2320 6420 6c65 7465 0a65 0000520 2020 2020 2020 2020 6962 646e 656b 2079 0000530 5c27 5b65 3b31 4335 2027 6f66 7772 7261 0000540 2d64 6f77 6472 2020 2020 2020 2020 2023 0000550 7463 6c72 7220 6769 7468 200a 2020 2020 0000560 2020 6220 6e69 6b64 7965 2720 655c 315b 0000570 353b 2744 6220 6361 776b 7261 2d64 6f77 0000580 6472 2020 2020 2320 6320 7274 206c 656c 0000590 7466 200a 2020 2020 2020 6220 6e69 6b64 00005a0 7965 2720 655c 315b 277e 2020 6220 6765 00005b0 6e69 696e 676e 6f2d 2d66 696c 656e 2020 00005c0 2020 2023 6f68 656d 200a 2020 2020 2020 00005d0 6220 6e69 6b64 7965 2720 655c 345b 277e 00005e0 2020 6520 646e 6f2d 2d66 696c 656e 2020 00005f0 2020 2020 2020 2020 2020 2020 2023 6e65 0000600 0a64 2020 2020 6e65 6964 0a66 000a 000060d
[yottabit@nas1 ~]$ hexdump /mnt/vol1/jacob.mcdonald_migrated/.zfs/snapshot/migration/.cshrc 0000000 0000 ea03 4bf1 2023 4624 6572 4265 4453 0000010 0a24 0a23 2023 632e 6873 6372 2d20 6320 0000020 6873 7220 7365 756f 6372 2065 6373 6972 0000030 7470 202c 6572 6461 6120 2074 6562 6967 0000040 6e6e 6e69 2067 666f 6520 6578 7563 6974 0000050 6e6f 6220 2079 6165 6863 7320 6568 6c6c 0000060 004f 7380 6565 6120 736c 4f6f f000 281b 0000070 2931 202c 6e65 6976 6f72 286e 2937 0a2e 0000080 2023 6f6d 6572 6520 6178 706d 656c 2073 0000090 7661 6961 616c 6c62 6365 b400 752f 7273 00000a0 732f 6168 6572 212f f300 2f0d 7363 2f68 00000b0 230a 0a0a 6c61 6169 2073 0968 6809 7369 00000c0 6f74 7972 3220 1435 a300 096a 6a09 626f 00000d0 2073 6c2d 0011 6c94 0961 736c 2d20 4661 00000e0 0010 6611 0010 4624 1041 1100 106c f000 00000f0 6c4f 4641 0a0a 2023 6854 7365 2065 7261 0000100 2065 6f6e 6d72 6c61 796c 7320 7465 7420 0000110 7268 756f 6867 2f20 7465 2f63 6f6c 6967 0000120 2e6e 6f63 666e 202e 5920 756f 6d20 7961 0000130 6f20 6576 7272 6469 2065 6874 6d65 6820 0000140 7265 0a65 2023 6669 7720 6e61 6574 eb64 0000150 0000 0048 00f1 6170 6874 3d20 2820 732f 0000160 6962 206e 052f 0100 00e7 0a05 0500 0009 0000170 6c57 636f 6c61 0019 1002 0000 001f 2450 0000180 4f48 454d 003c 2912 0056 16f2 6e65 0976 0000190 4c42 434f 534b 5a49 0945 0a4b 2023 2041 00001a0 6972 6867 6574 756f 2073 6d75 7361 0a6b 00001b0 0823 5300 3220 0a32 330a 9400 4445 5449 00001c0 524f 7609 1169 6000 4150 4547 0952 0192 00001d0 00f0 0a0a 6669 2820 3f24 7270 6d6f 7470 00001e0 d429 f200 6e04 090a 2023 6e41 6920 746e 00001f0 7265 6361 6974 6576 01e6 2031 2d2d 0123 0000200 00f1 6f73 656d 7320 7574 6666 7520 0a70 0000210 ee09 0100 003f 02f8 3d20 2220 4e25 2540 0000220 3a6d 7e25 2520 2023 1d22 5100 6863 7261 0000230 2273 3200 2223 190a 5200 6966 656c 0b63 0000240 0400 01de 3d62 3120 3030 1430 4000 6173 0000250 6576 0018 4700 0001 0016 2072 656d 6772 0000260 2965 001d 6152 7475 6c6f 001d 6190 626d 0000270 6769 6f75 7375 00b9 5540 6573 3520 0000 0000280 022b 01f6 6f74 6120 6469 6520 7078 6e61 0000290 6973 6e6f 003a 1301 1600 1064 6200 6572 00002a0 6168 6873 0010 6d40 6961 736c 5000 762f 00002b0 7261 0d2f 9000 242f 5355 5245 0a29 2b09 00002c0 4001 2420 743f 0330 2b04 f701 0913 6962 00002d0 646e 656b 2079 5e22 2257 6220 6361 776b 00002e0 7261 2d64 6564 656c 6574 772d 726f 2464 00002f0 5400 6b2d 7520 9f70 8400 732d 6165 6372 0000300 2d68 0034 280a 4c00 6f64 6e77 002a 6630 0000310 726f 005d 0a93 6509 646e 6669 0a0a 0007 0000320 970f 0000 2013 0001 9d0f 0f00 2903 0500 0000330 002a a30f 0b00 2e0f 0000 a90f 0900 2f0c 0000340 6000 5c27 5b65 2748 0016 5605 8004 6f2d 0000350 2d66 696c 656e 0015 2090 2320 6820 6d6f 0000360 0a65 000b 0200 0400 0095 3800 1100 3846 0000370 3a00 6e65 3264 0600 0002 234f 6520 736e 0000380 0300 3320 3c7e 0300 0193 8800 0602 0035 0000390 3801 0200 001a 760f 0200 3163 353b 2743 00003a0 7920 0101 01cf 3401 0100 0037 6342 7274 00003b0 7f6c 0f03 003b 2605 2744 0212 0b00 0802 00003c0 0039 6c3f 6665 0038 0104 00ae 210f 0201 00003d0 1f0f 0801 3411 0036 1f0f 0601 1d06 0301 00003e0 0235 001f 0001 dbff 0050 0000 0000 0000 00003f0 0000 0000 0000 0000 0000 0000 0000 0000 * 0000600 0000 0000 0000 0000 0000 0000 0000 000060d
$ md5sum ~/.zfs/snapshot/migration/.cshrc; find . -name .cshrc -exec md5sum '{}' \; eb4ea27bddb78d8caf944b9c0f76ccae /mnt/vol1/jacob.mcdonald/.zfs/snapshot/migration/.cshrc eb4ea27bddb78d8caf944b9c0f76ccae ./test_lz4_enc/.cshrc eb4ea27bddb78d8caf944b9c0f76ccae ./test_zstd_enc/.cshrc eb4ea27bddb78d8caf944b9c0f76ccae ./test_lz4/.cshrc eb4ea27bddb78d8caf944b9c0f76ccae ./test_zstd/.cshrc
$ md5sum ~/.zfs/snapshot/migration/.cshrc; find . -name .cshrc -exec md5sum '{}' \; eb4ea27bddb78d8caf944b9c0f76ccae /mnt/vol1/jacob.mcdonald/.zfs/snapshot/migration/.cshrc eb4ea27bddb78d8caf944b9c0f76ccae ./test_zstd_enc/.cshrc eb4ea27bddb78d8caf944b9c0f76ccae ./test_zstd/.cshrc
$ md5sum ~/.zfs/snapshot/migration/.cshrc /mnt/big_scratch/migration/test_zstd_intermediate/.zfs/snapshot/migration/.cshrc /mnt/vol1/test_zstd_enc_dest/.zfs/snapshot/migration/.cshrc eb4ea27bddb78d8caf944b9c0f76ccae /mnt/vol1/jacob.mcdonald/.zfs/snapshot/migration/.cshrc eb4ea27bddb78d8caf944b9c0f76ccae /mnt/big_scratch/migration/test_zstd_intermediate/.zfs/snapshot/migration/.cshrc eb4ea27bddb78d8caf944b9c0f76ccae /mnt/vol1/test_zstd_enc_dest/.zfs/snapshot/migration/.cshrc
here is the hexdump of the corrupted .cshrc file:
hexdump --canonical /mnt/vol1/jacob.mcdonald_migrated/.zfs/snapshot/migration/.cshrc
I can't reproduce this in CORE (ZFS 2.0.7).Looks LZ4-ish.
would you please run
Code:hexdump --canonical /mnt/vol1/jacob.mcdonald_migrated/.zfs/snapshot/migration/.cshrc
By the way, I think one of the requirements for a repro is changing LZ4 to ZSTD on the original dataset.
Therefore, ZFS reads data from the disk, verifies the checksum (which is correct), and then instead of decompressing, returns compressed data as is.
Ah, good call on sourcing the repro from a dataset changed from lz4 to zstd. I ignored that because I know that data has not been copied/recompressed since the compression property change, so at rest it's still lz4. But you make a good point. Except one difference is that the corruption happens after the data has (supposedly) been recompressed to zstd in the new intermediate dataset (successfully), and then replicated back to the old pool with either lz4 or zstd destination. But I will try to repro with the single-file dataset again using what I believe is the best history of my original pool. Sequence will be as follows:Looks LZ4-ish.
[yottabit@nas1 ~]$ hexdump --canonical /mnt/vol1/jacob.mcdonald/.zfs/snapshot/migration/.cshrc 00000000 23 20 24 46 72 65 65 42 53 44 24 0a 23 0a 23 20 |# $FreeBSD$.#.# | 00000010 2e 63 73 68 72 63 20 2d 20 63 73 68 20 72 65 73 |.cshrc - csh res| 00000020 6f 75 72 63 65 20 73 63 72 69 70 74 2c 20 72 65 |ource script, re| 00000030 61 64 20 61 74 20 62 65 67 69 6e 6e 69 6e 67 20 |ad at beginning | 00000040 6f 66 20 65 78 65 63 75 74 69 6f 6e 20 62 79 20 |of execution by | 00000050 65 61 63 68 20 73 68 65 6c 6c 0a 23 0a 23 20 73 |each shell.#.# s| 00000060 65 65 20 61 6c 73 6f 20 63 73 68 28 31 29 2c 20 |ee also csh(1), | 00000070 65 6e 76 69 72 6f 6e 28 37 29 2e 0a 23 20 6d 6f |environ(7)..# mo| 00000080 72 65 20 65 78 61 6d 70 6c 65 73 20 61 76 61 69 |re examples avai| 00000090 6c 61 62 6c 65 20 61 74 20 2f 75 73 72 2f 73 68 |lable at /usr/sh| 000000a0 61 72 65 2f 65 78 61 6d 70 6c 65 73 2f 63 73 68 |are/examples/csh| 000000b0 2f 0a 23 0a 0a 61 6c 69 61 73 20 68 09 09 68 69 |/.#..alias h..hi| 000000c0 73 74 6f 72 79 20 32 35 0a 61 6c 69 61 73 20 6a |story 25.alias j| 000000d0 09 09 6a 6f 62 73 20 2d 6c 0a 61 6c 69 61 73 20 |..jobs -l.alias | 000000e0 6c 61 09 6c 73 20 2d 61 46 0a 61 6c 69 61 73 20 |la.ls -aF.alias | 000000f0 6c 66 09 6c 73 20 2d 46 41 0a 61 6c 69 61 73 20 |lf.ls -FA.alias | 00000100 6c 6c 09 6c 73 20 2d 6c 41 46 0a 0a 23 20 54 68 |ll.ls -lAF..# Th| 00000110 65 73 65 20 61 72 65 20 6e 6f 72 6d 61 6c 6c 79 |ese are normally| 00000120 20 73 65 74 20 74 68 72 6f 75 67 68 20 2f 65 74 | set through /et| 00000130 63 2f 6c 6f 67 69 6e 2e 63 6f 6e 66 2e 20 20 59 |c/login.conf. Y| 00000140 6f 75 20 6d 61 79 20 6f 76 65 72 72 69 64 65 20 |ou may override | 00000150 74 68 65 6d 20 68 65 72 65 0a 23 20 69 66 20 77 |them here.# if w| 00000160 61 6e 74 65 64 2e 0a 23 20 73 65 74 20 70 61 74 |anted..# set pat| 00000170 68 20 3d 20 28 2f 73 62 69 6e 20 2f 62 69 6e 20 |h = (/sbin /bin | 00000180 2f 75 73 72 2f 73 62 69 6e 20 2f 75 73 72 2f 62 |/usr/sbin /usr/b| 00000190 69 6e 20 2f 75 73 72 2f 6c 6f 63 61 6c 2f 73 62 |in /usr/local/sb| 000001a0 69 6e 20 2f 75 73 72 2f 6c 6f 63 61 6c 2f 62 69 |in /usr/local/bi| 000001b0 6e 20 24 48 4f 4d 45 2f 62 69 6e 29 0a 23 20 73 |n $HOME/bin).# s| 000001c0 65 74 65 6e 76 09 42 4c 4f 43 4b 53 49 5a 45 09 |etenv.BLOCKSIZE.| 000001d0 4b 0a 23 20 41 20 72 69 67 68 74 65 6f 75 73 20 |K.# A righteous | 000001e0 75 6d 61 73 6b 0a 23 20 75 6d 61 73 6b 20 32 32 |umask.# umask 22| 000001f0 0a 0a 73 65 74 65 6e 76 09 45 44 49 54 4f 52 09 |..setenv.EDITOR.| 00000200 76 69 0a 73 65 74 65 6e 76 09 50 41 47 45 52 09 |vi.setenv.PAGER.| 00000210 6d 6f 72 65 0a 0a 69 66 20 28 24 3f 70 72 6f 6d |more..if ($?prom| 00000220 70 74 29 20 74 68 65 6e 0a 09 23 20 41 6e 20 69 |pt) then..# An i| 00000230 6e 74 65 72 61 63 74 69 76 65 20 73 68 65 6c 6c |nteractive shell| 00000240 20 2d 2d 20 73 65 74 20 73 6f 6d 65 20 73 74 75 | -- set some stu| 00000250 66 66 20 75 70 0a 09 73 65 74 20 70 72 6f 6d 70 |ff up..set promp| 00000260 74 20 3d 20 22 25 4e 40 25 6d 3a 25 7e 20 25 23 |t = "%N@%m:%~ %#| 00000270 20 22 0a 09 73 65 74 20 70 72 6f 6d 70 74 63 68 | "..set promptch| 00000280 61 72 73 20 3d 20 22 25 23 22 0a 0a 09 73 65 74 |ars = "%#"...set| 00000290 20 66 69 6c 65 63 0a 09 73 65 74 20 68 69 73 74 | filec..set hist| 000002a0 6f 72 79 20 3d 20 31 30 30 30 0a 09 73 65 74 20 |ory = 1000..set | 000002b0 73 61 76 65 68 69 73 74 20 3d 20 28 31 30 30 30 |savehist = (1000| 000002c0 20 6d 65 72 67 65 29 0a 09 73 65 74 20 61 75 74 | merge)..set aut| 000002d0 6f 6c 69 73 74 20 3d 20 61 6d 62 69 67 75 6f 75 |olist = ambiguou| 000002e0 73 0a 09 23 20 55 73 65 20 68 69 73 74 6f 72 79 |s..# Use history| 000002f0 20 74 6f 20 61 69 64 20 65 78 70 61 6e 73 69 6f | to aid expansio| 00000300 6e 0a 09 73 65 74 20 61 75 74 6f 65 78 70 61 6e |n..set autoexpan| 00000310 64 0a 09 73 65 74 20 61 75 74 6f 72 65 68 61 73 |d..set autorehas| 00000320 68 0a 09 73 65 74 20 6d 61 69 6c 20 3d 20 28 2f |h..set mail = (/| 00000330 76 61 72 2f 6d 61 69 6c 2f 24 55 53 45 52 29 0a |var/mail/$USER).| 00000340 09 69 66 20 28 20 24 3f 74 63 73 68 20 29 20 74 |.if ( $?tcsh ) t| 00000350 68 65 6e 0a 09 09 62 69 6e 64 6b 65 79 20 22 5e |hen...bindkey "^| 00000360 57 22 20 62 61 63 6b 77 61 72 64 2d 64 65 6c 65 |W" backward-dele| 00000370 74 65 2d 77 6f 72 64 0a 09 09 62 69 6e 64 6b 65 |te-word...bindke| 00000380 79 20 2d 6b 20 75 70 20 68 69 73 74 6f 72 79 2d |y -k up history-| 00000390 73 65 61 72 63 68 2d 62 61 63 6b 77 61 72 64 0a |search-backward.| 000003a0 09 09 62 69 6e 64 6b 65 79 20 2d 6b 20 64 6f 77 |..bindkey -k dow| 000003b0 6e 20 68 69 73 74 6f 72 79 2d 73 65 61 72 63 68 |n history-search| 000003c0 2d 66 6f 72 77 61 72 64 0a 09 65 6e 64 69 66 0a |-forward..endif.| 000003d0 0a 65 6e 64 69 66 0a 0a 69 66 20 28 20 24 3f 74 |.endif..if ( $?t| 000003e0 63 73 68 20 29 20 74 68 65 6e 0a 20 20 20 20 20 |csh ) then. | 000003f0 20 20 20 62 69 6e 64 6b 65 79 20 22 5e 57 22 20 | bindkey "^W" | 00000400 62 61 63 6b 77 61 72 64 2d 64 65 6c 65 74 65 2d |backward-delete-| 00000410 77 6f 72 64 0a 20 20 20 20 20 20 20 20 62 69 6e |word. bin| 00000420 64 6b 65 79 20 2d 6b 20 75 70 20 68 69 73 74 6f |dkey -k up histo| 00000430 72 79 2d 73 65 61 72 63 68 2d 62 61 63 6b 77 61 |ry-search-backwa| 00000440 72 64 0a 20 20 20 20 20 20 20 20 62 69 6e 64 6b |rd. bindk| 00000450 65 79 20 2d 6b 20 64 6f 77 6e 20 68 69 73 74 6f |ey -k down histo| 00000460 72 79 2d 73 65 61 72 63 68 2d 66 6f 72 77 61 72 |ry-search-forwar| 00000470 64 0a 20 20 20 20 20 20 20 20 62 69 6e 64 6b 65 |d. bindke| 00000480 79 20 27 5c 65 5b 48 27 20 20 20 20 62 65 67 69 |y '\e[H' begi| 00000490 6e 6e 69 6e 67 2d 6f 66 2d 6c 69 6e 65 20 20 20 |nning-of-line | 000004a0 20 20 20 23 20 68 6f 6d 65 0a 20 20 20 20 20 20 | # home. | 000004b0 20 20 62 69 6e 64 6b 65 79 20 27 5c 65 5b 46 27 | bindkey '\e[F'| 000004c0 20 20 20 20 65 6e 64 2d 6f 66 2d 6c 69 6e 65 20 | end-of-line | 000004d0 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 23 | #| 000004e0 20 65 6e 64 0a 20 20 20 20 20 20 20 20 62 69 6e | end. bin| 000004f0 64 6b 65 79 20 27 5c 65 5b 33 7e 27 20 20 20 64 |dkey '\e[3~' d| 00000500 65 6c 65 74 65 2d 63 68 61 72 20 20 20 20 20 20 |elete-char | 00000510 20 20 20 20 20 20 20 23 20 64 65 6c 65 74 65 0a | # delete.| 00000520 20 20 20 20 20 20 20 20 62 69 6e 64 6b 65 79 20 | bindkey | 00000530 27 5c 65 5b 31 3b 35 43 27 20 66 6f 72 77 61 72 |'\e[1;5C' forwar| 00000540 64 2d 77 6f 72 64 20 20 20 20 20 20 20 20 23 20 |d-word # | 00000550 63 74 72 6c 20 72 69 67 68 74 0a 20 20 20 20 20 |ctrl right. | 00000560 20 20 20 62 69 6e 64 6b 65 79 20 27 5c 65 5b 31 | bindkey '\e[1| 00000570 3b 35 44 27 20 62 61 63 6b 77 61 72 64 2d 77 6f |;5D' backward-wo| 00000580 72 64 20 20 20 20 20 23 20 63 74 72 6c 20 6c 65 |rd # ctrl le| 00000590 66 74 0a 20 20 20 20 20 20 20 20 62 69 6e 64 6b |ft. bindk| 000005a0 65 79 20 27 5c 65 5b 31 7e 27 20 20 20 62 65 67 |ey '\e[1~' beg| 000005b0 69 6e 6e 69 6e 67 2d 6f 66 2d 6c 69 6e 65 20 20 |inning-of-line | 000005c0 20 20 23 20 68 6f 6d 65 0a 20 20 20 20 20 20 20 | # home. | 000005d0 20 62 69 6e 64 6b 65 79 20 27 5c 65 5b 34 7e 27 | bindkey '\e[4~'| 000005e0 20 20 20 65 6e 64 2d 6f 66 2d 6c 69 6e 65 20 20 | end-of-line | 000005f0 20 20 20 20 20 20 20 20 20 20 20 20 23 20 65 6e | # en| 00000600 64 0a 20 20 20 20 65 6e 64 69 66 0a 0a |d. endif..| 0000060d
[yottabit@nas1 ~]$ hexdump --canonical /mnt/vol1/jacob.mcdonald_migrated/.zfs/snapshot/migration/.cshrc 00000000 00 00 03 ea f1 4b 23 20 24 46 72 65 65 42 53 44 |.....K# $FreeBSD| 00000010 24 0a 23 0a 23 20 2e 63 73 68 72 63 20 2d 20 63 |$.#.# .cshrc - c| 00000020 73 68 20 72 65 73 6f 75 72 63 65 20 73 63 72 69 |sh resource scri| 00000030 70 74 2c 20 72 65 61 64 20 61 74 20 62 65 67 69 |pt, read at begi| 00000040 6e 6e 69 6e 67 20 6f 66 20 65 78 65 63 75 74 69 |nning of executi| 00000050 6f 6e 20 62 79 20 65 61 63 68 20 73 68 65 6c 6c |on by each shell| 00000060 4f 00 80 73 65 65 20 61 6c 73 6f 4f 00 f0 1b 28 |O..see alsoO...(| 00000070 31 29 2c 20 65 6e 76 69 72 6f 6e 28 37 29 2e 0a |1), environ(7)..| 00000080 23 20 6d 6f 72 65 20 65 78 61 6d 70 6c 65 73 20 |# more examples | 00000090 61 76 61 69 6c 61 62 6c 65 63 00 b4 2f 75 73 72 |availablec../usr| 000000a0 2f 73 68 61 72 65 2f 21 00 f3 0d 2f 63 73 68 2f |/share/!.../csh/| 000000b0 0a 23 0a 0a 61 6c 69 61 73 20 68 09 09 68 69 73 |.#..alias h..his| 000000c0 74 6f 72 79 20 32 35 14 00 a3 6a 09 09 6a 6f 62 |tory 25...j..job| 000000d0 73 20 2d 6c 11 00 94 6c 61 09 6c 73 20 2d 61 46 |s -l...la.ls -aF| 000000e0 10 00 11 66 10 00 24 46 41 10 00 11 6c 10 00 f0 |...f..$FA...l...| 000000f0 4f 6c 41 46 0a 0a 23 20 54 68 65 73 65 20 61 72 |OlAF..# These ar| 00000100 65 20 6e 6f 72 6d 61 6c 6c 79 20 73 65 74 20 74 |e normally set t| 00000110 68 72 6f 75 67 68 20 2f 65 74 63 2f 6c 6f 67 69 |hrough /etc/logi| 00000120 6e 2e 63 6f 6e 66 2e 20 20 59 6f 75 20 6d 61 79 |n.conf. You may| 00000130 20 6f 76 65 72 72 69 64 65 20 74 68 65 6d 20 68 | override them h| 00000140 65 72 65 0a 23 20 69 66 20 77 61 6e 74 65 64 eb |ere.# if wanted.| 00000150 00 00 48 00 f1 00 70 61 74 68 20 3d 20 28 2f 73 |..H...path = (/s| 00000160 62 69 6e 20 2f 05 00 01 e7 00 05 0a 00 05 09 00 |bin /...........| 00000170 57 6c 6f 63 61 6c 19 00 02 10 00 00 1f 00 50 24 |Wlocal........P$| 00000180 48 4f 4d 45 3c 00 12 29 56 00 f2 16 65 6e 76 09 |HOME<..)V...env.| 00000190 42 4c 4f 43 4b 53 49 5a 45 09 4b 0a 23 20 41 20 |BLOCKSIZE.K.# A | 000001a0 72 69 67 68 74 65 6f 75 73 20 75 6d 61 73 6b 0a |righteous umask.| 000001b0 23 08 00 53 20 32 32 0a 0a 33 00 94 45 44 49 54 |#..S 22..3..EDIT| 000001c0 4f 52 09 76 69 11 00 60 50 41 47 45 52 09 92 01 |OR.vi..`PAGER...| 000001d0 f0 00 0a 0a 69 66 20 28 24 3f 70 72 6f 6d 70 74 |....if ($?prompt| 000001e0 29 d4 00 f2 04 6e 0a 09 23 20 41 6e 20 69 6e 74 |)....n..# An int| 000001f0 65 72 61 63 74 69 76 65 e6 01 31 20 2d 2d 23 01 |eractive..1 --#.| 00000200 f1 00 73 6f 6d 65 20 73 74 75 66 66 20 75 70 0a |..some stuff up.| 00000210 09 ee 00 01 3f 00 f8 02 20 3d 20 22 25 4e 40 25 |....?... = "%N@%| 00000220 6d 3a 25 7e 20 25 23 20 22 1d 00 51 63 68 61 72 |m:%~ %# "..Qchar| 00000230 73 22 00 32 23 22 0a 19 00 52 66 69 6c 65 63 0b |s".2#"...Rfilec.| 00000240 00 04 de 01 62 3d 20 31 30 30 30 14 00 40 73 61 |....b= 1000..@sa| 00000250 76 65 18 00 00 47 01 00 16 00 72 20 6d 65 72 67 |ve...G....r merg| 00000260 65 29 1d 00 52 61 75 74 6f 6c 1d 00 90 61 6d 62 |e)..Rautol...amb| 00000270 69 67 75 6f 75 73 b9 00 40 55 73 65 20 35 00 00 |iguous..@Use 5..| 00000280 2b 02 f6 01 74 6f 20 61 69 64 20 65 78 70 61 6e |+...to aid expan| 00000290 73 69 6f 6e 3a 00 01 13 00 16 64 10 00 62 72 65 |sion:.....d..bre| 000002a0 68 61 73 68 10 00 40 6d 61 69 6c 73 00 50 2f 76 |hash..@mails.P/v| 000002b0 61 72 2f 0d 00 90 2f 24 55 53 45 52 29 0a 09 2b |ar/.../$USER)..+| 000002c0 01 40 20 24 3f 74 30 03 04 2b 01 f7 13 09 62 69 |.@ $?t0..+....bi| 000002d0 6e 64 6b 65 79 20 22 5e 57 22 20 62 61 63 6b 77 |ndkey "^W" backw| 000002e0 61 72 64 2d 64 65 6c 65 74 65 2d 77 6f 72 64 24 |ard-delete-word$| 000002f0 00 54 2d 6b 20 75 70 9f 00 84 2d 73 65 61 72 63 |.T-k up...-searc| 00000300 68 2d 34 00 0a 28 00 4c 64 6f 77 6e 2a 00 30 66 |h-4..(.Ldown*.0f| 00000310 6f 72 5d 00 93 0a 09 65 6e 64 69 66 0a 0a 07 00 |or]....endif....| 00000320 0f 97 00 00 13 20 01 00 0f 9d 00 0f 03 29 00 05 |..... .......)..| 00000330 2a 00 0f a3 00 0b 0f 2e 00 00 0f a9 00 09 0c 2f |*............../| 00000340 00 60 27 5c 65 5b 48 27 16 00 05 56 04 80 2d 6f |.`'\e[H'...V..-o| 00000350 66 2d 6c 69 6e 65 15 00 90 20 20 23 20 68 6f 6d |f-line... # hom| 00000360 65 0a 0b 00 00 02 00 04 95 00 00 38 00 11 46 38 |e..........8..F8| 00000370 00 3a 65 6e 64 32 00 06 02 00 4f 23 20 65 6e 73 |.:end2....O# ens| 00000380 00 03 20 33 7e 3c 00 03 93 01 00 88 02 06 35 00 |.. 3~<........5.| 00000390 01 38 00 02 1a 00 0f 76 00 02 63 31 3b 35 43 27 |.8.....v..c1;5C'| 000003a0 20 79 01 01 cf 01 01 34 00 01 37 00 42 63 74 72 | y.....4..7.Bctr| 000003b0 6c 7f 03 0f 3b 00 05 26 44 27 12 02 00 0b 02 08 |l...;..&D'......| 000003c0 39 00 3f 6c 65 66 38 00 04 01 ae 00 0f 21 01 02 |9.?lef8......!..| 000003d0 0f 1f 01 08 11 34 36 00 0f 1f 01 06 06 1d 01 03 |.....46.........| 000003e0 35 02 1f 00 01 00 ff db 50 00 00 00 00 00 00 00 |5.......P.......| 000003f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| * 00000600 00 00 00 00 00 00 00 00 00 00 00 00 00 |.............| 0000060d
[yottabit@nas1 ~]$ md5sum /mnt/vol1/jacob.mcdonald/.zfs/snapshot/migration/.cshrc eb4ea27bddb78d8caf944b9c0f76ccae /mnt/vol1/jacob.mcdonald/.zfs/snapshot/migration/.cshrc [yottabit@nas1 ~]$ md5sum /mnt/vol1/jacob.mcdonald_migrated/.zfs/snapshot/migration/.cshrc 16da5f6ca9fb073a578996c538b3167c /mnt/vol1/jacob.mcdonald_migrated/.zfs/snapshot/migration/.cshrc [yottabit@nas1 ~]$ md5sum /mnt/vol1/jacob.mcdonald_migrated_lz4_lz4/.zfs/snapshot/migration/.cshrc eb4ea27bddb78d8caf944b9c0f76ccae /mnt/vol1/jacob.mcdonald_migrated_lz4_lz4/.zfs/snapshot/migration/.cshrc
This is something that stands out. Very old zpool from the FreeNAS 9 era, replicating into TrueNAS SCALE with ZFS 2.1, and then back again to a different dataset on the old pool.Old pool, consisting of 2x Z1 vdevs of different ages, originally created around FreeNAS 9, dataset is lz4 compression for most of its life, dozen or so snapshots, ~2 TiB data, ~4 TiB dataset size (with snapshots)
I don't believe ZSTD was a supported compression property back then? Did you upgrade the old pool's features prior to these replications?Replicate intermedate dataset to the destination dataset on the old pool; target properties were zstd compression and password encryption
I can't figure out what's causing this for @yottabit.The corrupted file is, in fact LZ4-compressed data as is.
During replication, it does change the compression mode in the block pointer as requested but does not actually recompress the data. This way, when you copy to the LZ4-compressed dataset, there is no problem as no recompression is needed. I wonder if the problem persists if the target dataset uses LZJB compression.
