mazdajai
 - Jul 15, 2011
I am running FreeNAS-11.2-U8 and trying to detach a failed disk that is stuck on replacing status for couple days.
The failed disk was replacing via GUI. (Server shutdown, swap disk, wipe new disk and "Replace" option under pool. Is there anything else I can do such as checking replacing /resilvering status before I have to redo the pool?
  pool: vol1
 state: DEGRADED
    corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
    entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: resilvered 676G in 0 days 03:09:16 with 16348 errors on Sat Dec 19 18:22:20 2020
    NAME                                              STATE     READ WRITE CKSUM
    vol1                                              DEGRADED     0     0 19.8K
      raidz1-0                                        DEGRADED     0     0 47.6K
        gptid/158a0c38-1c89-11eb-896f-001e674758cd    ONLINE       0     0     0  block size: 512B configured, 4096B native
        gptid/53fc6bb4-e3b4-11e2-9dcd-003018a56e64    DEGRADED     0     0     0  too many errors
        gptid/547d76c5-e3b4-11e2-9dcd-003018a56e64    DEGRADED     0     0     0  too many errors
        gptid/5502f4d4-e3b4-11e2-9dcd-003018a56e64    DEGRADED     0     0     0  too many errors
        replacing-4                                   UNAVAIL      0     0     0
          17085095126061593047                        UNAVAIL      0     0     0  was /dev/ada4p2
          gptid/d62a52fa-4235-11eb-8374-001e674758cd  ONLINE       0     0     0
errors: 16081 data errors, use '-v' for a list
