I'm just curious. . .are you running SAS and SATA in the same pool and on the same controller/expander?
Yes, the 3 in that one vdev are 20tb SATA drives. They were running fine zero issues for about a month and half and then one of them started saying it could not read SMART data on da17 (one of those). I ended up RMAing it after a few weeks, then during the resilver process it started giving me this issue and showing a ton of other drives as degraded.
It's been about a month and a half it's been like this, because I've been so busy with work. However I hadn't notced the SMART data on da17 issue since replacing it, despite all the other drives showing degraded. However, about a week ago, it randomly started showing that same error again, alongside all the other new ones.
All the other drives are SAS drives.
I have x2 LSI cards (IT MODE) in my system, there is I think 48 bays. So there are bays on the front of the system, and the back. The 3 20TB drives are on the back, and all the others are currently on the front.
However like I said, everything was working fine for like a month after adding in the 20tb drives, except that SMART could not read on da17 error, which I then replaced that specific drive with RMA, and then that's when it all went to hell.
I will check the include SAS line in the script thanks
CRITICAL
Pool PrimaryPool state is DEGRADED: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
The following devices are not healthy:
Disk HITACHI HUS72604CLAR4000 K4K7KU5B is UNAVAIL
Disk HITACHI HUS72604CLAR4000 K4K6EM8B is UNAVAIL
Disk HGST HUS726040AL4210 NHG9JAAY is DEGRADED
Disk HGST HUS726040AL4210 NHGAJWEY is DEGRADED
Disk ATA ST20000NM007D-3D ZVT06KLB is DEGRADED
Disk ATA ST20000NM007D-3D ZVT5J3MY is DEGRADED
Disk ATA ST20000NM007D-3D ZVT5JPF5 is FAULTED
Disk HGST HUS726040AL4210 NHG9ZP7Y is DEGRADED
Disk SEAGATE ST4000NXCLAR4000 Z1Z2428B 0000C4118VDG is DEGRADED
2024-02-10 10:35:17 (America/New_York)
Dismiss
notifications_active
CRITICAL
Device: /dev/da17 [SAT], failed to read SMART Attribute Data.
2024-02-10 10:34:36 (America/New_York)
Dismiss
Please try to follow the
Getting Started directions as closely as possible.
I did like 3 times however I will look again
