Jimbob
- Jun 8, 2023
TrueNAS-13.0-U4 Core, AMD 3950x, 128gb ECC RAM, ASROCK - X570M Pro4 MOBO
BACK STORY - Had 2x failed disks. Physically removed them. Added new discs. Chose replace from the menu following the DISK REPLACE GUIDE. Resilvered. Scrubbed & SMART tested. All show no errors post resilvering / no email alerts. Still showing as DEGRADED with ghost drives listed in the pool status.
NOW - I now have the old drives showing in pool / status & pool saying ‘degraded’, with the drives status as offline & unavailable. Out of ideas, need a lil expert halping! Be good to clean this up & fix the degraded state. My N00B guess is a conflict after a few weeks research.
I have tried the online / take offline trick a few times. Just made more confusion as da7 ghosted around.
Detach & remove don’t work (throw errors) & the spare drive sort of moves around / phantom ghosts as well.
Found some threads on this BUT seem close BUT not relevant. Disk set all looks fine (13 in total).
Tried shell commands for 'zpool remove / detach' which didn't work.
Zpool status -v below.
root@truenas[~]# zpool status -v
pool: BigBoi
state: DEGRADED
status: One or more devices has been taken offline by the administrator.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: scrub repaired 0B in 08:54:47 with 0 errors on Sun Jun 18 08:54:47 2023
NAME STATE READ WRITE CKSUM
Barrel DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/16ea0816-dd57-11eb-ab6d-a8a15938b457 ONLINE 0 0 0
gptid/16a7f8e2-dd57-11eb-ab6d-a8a15938b457 ONLINE 0 0 0
gptid/16c3758f-dd57-11eb-ab6d-a8a15938b457 ONLINE 0 0 0
gptid/16cf24a0-dd57-11eb-ab6d-a8a15938b457 ONLINE 0 0 0
spare-4 DEGRADED 0 0 0
gptid/a946fb3c-05d6-11ee-8f4a-a8a15938b457 ONLINE 0 0 0
11113997412615612199 OFFLINE 0 0 0 was /dev/gptid/d3683bab-de07-11eb-ab6d-a8a15938b457
gptid/5592df15-05d9-11ee-8f4a-a8a15938b457 OFFLINE 0 0 0
gptid/1863c5af-dd57-11eb-ab6d-a8a15938b457 ONLINE 0 0 0
gptid/1842b18e-dd57-11eb-ab6d-a8a15938b457 ONLINE 0 0 0
gptid/18579aaa-dd57-11eb-ab6d-a8a15938b457 ONLINE 0 0 0
gptid/18246fdb-dd57-11eb-ab6d-a8a15938b457 ONLINE 0 0 0
gptid/18821fbd-dd57-11eb-ab6d-a8a15938b457 ONLINE 0 0 0
spares
gptid/d3683bab-de07-11eb-ab6d-a8a15938b457 UNAVAIL cannot open
gptid/5592df15-05d9-11ee-8f4a-a8a15938b457 AVAIL
errors: No known data errors
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:07 with 0 errors on Sat Jun 17 03:45:08 2023
LINKS & RESOURCES
Unable to detach missing drive (2017).
Replacement Disk Unable to Detach (2020).
pool: BigBoi
state: DEGRADED
degraded state.
'zpool replace'.
spares
pool: boot-pool
state: ONLINE
LINKS & RESOURCES
