Nik Ansell
- Oct 28, 2014
Hello All,
I am new to FreeNAS but loving it so far. It's really simple to get up and running and the plugins really make it worthwhile. The performance by far exceeds my previous iomega NAS too :)
My question is related to replacing a disk in a UFS RAID 5 volume.
I have a 4 disk volume named vol1 in a RAID 5 set using UFS, dmesg section below:
GEOM_STRIPE: Device vol1 created (id=3008995252).
GEOM_STRIPE: Disk ada3 attached to vol1.
GEOM_STRIPE: Disk ada2 attached to vol1.
GEOM_STRIPE: Disk ada1 attached to vol1.
GEOM_STRIPE: Disk ada0 attached to vol1.
GEOM_STRIPE: Device stripe/vol1 activated.
GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
One of my drives (/dev/ada0) has a number of unreadable sectors which is gradually increasing and I would like to replace the disk.
My experience of RAID is many years old and always using hardware RAID in servers, such as Compaq/HP, Dell etc. In the past when a drive has failed, I have simply pulled the disk out, replaced it with another, then told the RAID controller/RAID software to rebuild the data on the new disk using the parity across the other disks in the set.
However.... I cannot figure out how to do this in FreeNAS. I have read the manual and searched all over the web and this forum and can only find examples of replacing a disk which has FAILED completely. I cannot see an option in the GUI to REPLACE, or Take OFFLINE anywhere as stated in the manual.
Would someone be kind enough to walk me through the steps I should take, to remove one disk, replace it with another and kick off the data rebuild. I am reasonably comfortable in a shell if needed.
Thank you in advance!
Kind Regards,
Nik
More relevant info from dmseg below...
FreeBSD 9.2-RELEASE-p12 #0 r262572+b043649: Sun Sep 28 23:03:31 PDT 2014
root@build3.ixsystems.com:/tank/home/jkh/build/921/freenas/os-base/amd64/fusion/jkh/921/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz (3400.07-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x306c3 Family = 0x6 Model = 0x3c Stepping = 3
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x7fdafbbf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,<b11>,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
AMD Features2=0x21<LAHF,ABM>
Standard Extended Features=0x27ab<GSFSBASE,TSCADJ,SMEP,ENHMOVSB,INVPCID>
TSC: P-state invariant, performance statistics
real memory = 8589934592 (8192 MB)
avail memory = 8100642816 (7725 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <ALASKA A M I>
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 SMT threads
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <Hitachi HDS5C3020ALA632 ML6OA5C0> ATA-8 SATA 3.x device
ada0: Serial Number ML2220F31WJ11H
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada0: Previously was known as ad4
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <Hitachi HDS5C3020ALA632 ML6OA5C0> ATA-8 SATA 3.x device
ada1: Serial Number ML2220F31YKJ2H
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada1: Previously was known as ad6
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <Hitachi HDS5C3020ALA632 ML6OA5C0> ATA-8 SATA 3.x device
ada2: Serial Number ML2220F31WR1LE
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada2: Previously was known as ad8
ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
ada3: <Hitachi HDS5C3020ALA632 ML6OA5C0> ATA-8 SATA 3.x device
ada3: Serial Number ML2220F31XKSSH
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada3: Previously was known as ad10
Kind Regards,
Nik
