Replace Harddrive with CHK Error and Read/Write Error?
eichof
Since a few days I've a problem with my freenas installation and ZFS.
Freenas tells me that I've six checksum errors on one singel drive (3 x 3TB setup) the harddrive has also 2.9K write and 2.02M read. The two other hdd's are fine.
I've done a memtest86+ run with 10 passes without errors just to be sure there is no ram problem (I use 16GB non ecc).
I also did a short smart test on that drive and the drive passed it.
What would you suggest to me? Can the ZFS clean it up, when the other two disk's are fine? Should I send the drive back RMA?
thx,
PS: I know ECC RAM is a must, I will upgrade the hole system in a few months either...
ada0 is almost certainly failing. You don't rack up 2 million read errors because your hard drive got bored.
That's actually 2.9K read and 2.02M write, unless I've completely forgotten my German. The drive's SMART data (smartctl -a /dev/ada0) would be relevant information, but it's agree with @cyberjock that it's almost certainly dying.
eichof
danb35 yes ofcourse you are right it's 2.9k read and 2.02M write. thx.
Here are the smart values...
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 195 177 021 Pre-fail Always - 5208
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 40
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2024
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 39
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 17
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 103
194 Temperature_Celsius 0x0022 119 104 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 2019 -
# 2 Short offline Completed without error 00% 2017 -
# 3 Extended offline Aborted by host 90% 2017 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
eichof
Actualy my system is grubbing and resilvering the hd in a loop, the read/write errors get periodicly changed. What does that mean?
THX!
eichof
After changing the sata cable from ada0 the server is running again puhh!
And I also did a long smart test the hd seems to be fine, so I think it was only a broken cable.
3 Spin_Up_Time 0x0027 212 177 021 Pre-fail Always - 4358
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 44
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 2039
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 42
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 19
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 106
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
No Errors Logged
# 1 Extended offline Completed without error 00% 2038 -
# 2 Short offline Completed without error 00% 2019 -
# 3 Short offline Completed without error 00% 2017 -
# 4 Extended offline Aborted by host 90% 2017 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas ~]# ^C
[root@freenas
