Remove hot spare?
urbansystems
I recently added a hot spare to my system. I had another disk fail, and when it tried to use the hot spare it failed. I got the other disk working, and now I want to remove the hot spare. I removed it from the GUI and I removed it physically. My pool still shows up degraded. How do I completely remove it, and make the pool happy again?
Thanks
  pool: freenas-boot
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
    still be used, but some features are unavailable.
    the features. See zpool-features(5) for details.
  scan: scrub repaired 0B in 00:01:20 with 0 errors on Tue Jun  7 03:46:20 2022
    NAME          STATE     READ WRITE CKSUM
    freenas-boot  ONLINE       0     0     0
      mirror-0    ONLINE       0     0     0
        ada0p2    ONLINE       0     0     0
        ada1p2    ONLINE       0     0     0
errors: No known data errors
  pool: nearline
 state: DEGRADED
status: One or more devices has been taken offline by the administrator.
    Sufficient replicas exist for the pool to continue functioning in a
    degraded state.
action: Online the device using 'zpool online' or replace the device with
    'zpool replace'.
  scan: resilvered 2.91T in 4 days 17:55:21 with 0 errors on Thu Jun  9 19:56:55 2022
    nearline                                        DEGRADED     0     0     0
      raidz3-0                                      DEGRADED     0     0     0
        gptid/b43d4d9d-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b4043f54-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/13db5bf6-d51c-11ec-a001-a0369fbd07a0  ONLINE       0     0     0
        gptid/a991a2e5-cbba-11ec-8535-a0369fbd07a0  ONLINE       0     0     0
        gptid/b45e3523-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b46a1f76-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/267bb1a8-b420-11ec-b200-a0369fbd07a0  ONLINE       0     0     0
        gptid/b448e85b-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b4565aaf-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b4505acf-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/22f70be9-d520-11ec-a001-a0369fbd07a0  OFFLINE      0     0     0
        gptid/b48ec171-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b4f4f465-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b4d1e54b-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b4fcf6f2-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b57b1a62-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b5d0c057-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/198f66cb-b9bc-11ec-8161-a0369fbd07a0  ONLINE       0     0     0
        gptid/b5e0f58c-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b5e52ef2-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b5efa0bf-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b602cde1-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
        gptid/b601fab1-8da5-11ec-b235-a0369fbd07a2  ONLINE       0     0     0
That's not currently a hot-spare, it's part of your pool and needs to be replaced with a disk that's online... maybe just setting it online will change something.
So the option you had taken before resulted in the hot-spare disk becoming a permanent pool member and the "replaced disk" was removed.
With that drive out of the system, of course it was showing as offline.
When you have a failure taken over with an hot-spare, you either need to replace the failed disk again and return the hot-spare or you keep the hot-spare as a permanent pool member and add a new one (if you want). You took the second option.
