calgarychris
 - Aug 27, 2011
Just wondering if anyone has encountered the following error trying to implement SSL on Sickbeard:
Running 9.1.1 Release with a freshly installed jail. I subsequently built py-openssl and py-openssl-proxy from ports however this error persists. Any ideas?
Thanks
Chris
File "/usr/pbi/sickbeard-amd64/SickBeard/SickBeard.py", line 354, in <module>
    main()
  File "/usr/pbi/sickbeard-amd64/SickBeard/SickBeard.py", line 316, in main
    'https_key': sickbeard.HTTPS_KEY,
  File "/usr/pbi/sickbeard-amd64/SickBeard/sickbeard/webserveInit.py", line 157,
 in initWebServer
    cherrypy.server.start()
  File "/usr/pbi/sickbeard-amd64/SickBeard/cherrypy/_cpserver.py", line 85, in s
tart
    self.httpserver, self.bind_addr = self.httpserver_from_self()
  File "/usr/pbi/sickbeard-amd64/SickBeard/cherrypy/_cpserver.py", line 76, in h
ttpserver_from_self
    httpserver = _cpwsgi_server.CPWSGIServer(self)
  File "/usr/pbi/sickbeard-amd64/SickBeard/cherrypy/_cpwsgi_server.py", line 62,
 in __init__
    self.server_adapter.ssl_certificate_chain)
  File "/usr/pbi/sickbeard-amd64/SickBeard/cherrypy/wsgiserver/ssl_pyopenssl.py"
, line 158, in __init__
    raise ImportError("You must install pyOpenSSL to use HTTPS.")
ImportError: You must install pyOpenSSL to use HTTPS.Running 9.1.1 Release with a freshly installed jail. I subsequently built py-openssl and py-openssl-proxy from ports however this error persists. Any ideas?
Thanks
Chris
