I installed the Redmine plugin. At the end of the installation, it gives a general status summary. For the most part, it looks like all systems are "go", but I see the following two lines, twice:
This concerned me, but since I'm new, I decided to press forward. Launching the website that's supposed to present Redmine produced a "Bad Gateway" error. After some digging, I figured out it's because Redmine is supposed to run as a service, which nginx connects with on a localhost port. The problem is, there's no redmine service. It turns out Redmine is not installed:
So I did a
Does this mean the plugin definition is behind the current version of redmine that's available? How can this be fixed? I don't suppose simply allowing the install to proceed would result in a working system...?
redmine does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d), or is not executableThis concerned me, but since I'm new, I decided to press forward. Launching the website that's supposed to present Redmine produced a "Bad Gateway" error. After some digging, I figured out it's because Redmine is supposed to run as a service, which nginx connects with on a localhost port. The problem is, there's no redmine service. It turns out Redmine is not installed:
pkg query -a '%n' | grep redmine returns nothing.So I did a
pkg install redmine and got the following:All repositories are up to date.
Checking integrity... done (1 conflicting)
- mysql57-client-5.7.26 conflicts with mysql56-client-5.6.44 on /usr/local/bin/mysql
Checking integrity... done (0 conflicting)
The following 5 package(s) will be affected (of 0 checked):
Installed packages to be REMOVED:
mysql56-server-5.6.44
New packages to be INSTALLED:
redmine: 3.4.9_2
rubygem-mysql2: 0.4.10
mysql57-client: 5.7.26
Number of packages to be removed: 2
Number of packages to be installed: 3
The operation will free 60 MiB.
Proceed with this action? [y/N]:Does this mean the plugin definition is behind the current version of redmine that's available? How can this be fixed? I don't suppose simply allowing the install to proceed would result in a working system...?
