davidnjina
- Feb 7, 2019
Hello there,
I think I messed up my server and I need help.
Here is my setup:
FreeNAS-11.2-RELEASE-U1
Two raidz2 with six drives each. One of 4TB drive became unavailable? (I don't remember but one HD was causing the degraded stage) so I shutoff the server and removed the disk. I then 'replaced' it with new drive and selected from menu to 'replace'. Afterward, I realized that I should have offline the drive first. I am wondering if it's too late to recover from my mistake.
I do have the entire data backuped to backblaze and I also have a local backup as well so I am not worried about losing anything. However, for the sake of learning from my mistake (and to inform others), I just wanted to throw this question out.
Can you advise if I can recover from this without restoring the entire pool from backup? Thank you for your help.
Now when I run 'zpool status', i get the following:
Here is my setup:
pool: Poolz
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
scan: scrub repaired 0 in 0 days 02:50:59 with 19 errors on Fri Mar 22 04:50:1 7 2019
NAME STATE READ WRITE C KSUM
Poolz DEGRADED 0 0 59
raidz2-0 ONLINE 0 0 118
gptid/5b236101-21f2-11e9-bfe3-0cc47ab00066 ONLINE 0 0 0
gptid/5ccc3997-21f2-11e9-bfe3-0cc47ab00066 ONLINE 0 0 0
gptid/5e7f3bca-21f2-11e9-bfe3-0cc47ab00066 ONLINE 0 0 0
gptid/601d70f8-21f2-11e9-bfe3-0cc47ab00066 ONLINE 0 0 0
gptid/62369848-21f2-11e9-bfe3-0cc47ab00066 ONLINE 0 0 0
gptid/644c4e68-21f2-11e9-bfe3-0cc47ab00066 ONLINE 0 0 0
raidz2-1 DEGRADED 0 0 0
replacing-0 DEGRADED 0 0 0
6104361762671653169 OFFLINE 0 0 0 was /dev/gptid/d03b3fe1-2536-11e9-99bf-0cc47ab00066
gptid/8cd32a44-4c20-11e9-a824-0cc47ab00066 ONLINE 0 0 0
gptid/d495a6de-2536-11e9-99bf-0cc47ab00066 ONLINE 0 0 0
gptid/d8d8554f-2536-11e9-99bf-0cc47ab00066 ONLINE 0 0 0
gptid/dd3c1366-2536-11e9-99bf-0cc47ab00066 ONLINE 0 0 0
gptid/e0f66452-2536-11e9-99bf-0cc47ab00066 ONLINE 0 0 0
gptid/e3bfc2bb-2536-11e9-99bf-0cc47ab00066 ONLINE 0 0 0
