recover zpool that can't be imported
Had some issues with the motherboard of the old system. I moved the disk to a different system and made no changes to export previously. When the system boots it finds the pool but cant import due to the faulted state captured below. How do I determine which disk it is reporting as offline. I am not sure how to correlate the highlighted number to the serial number. If I isolate that disk would I still be able to import the pool?
pool: NAPLES-SATA-RAIDZ-VOLUME
state: FAULTED
status: The pool was last accessed by another system.
action: The pool cannot be imported due to damaged devices or data.
The pool may be active on another system, but can be imported using
the '-f' flag.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-EY
NAPLES-SATA-RAIDZ-VOLUME FAULTED corrupted data
raidz1-0 DEGRADED
gptid/4b056d4d-3da1-11ed-9ec7-ac1f6beb0f4c ONLINE
gptid/4ad5382d-3da1-11ed-9ec7-ac1f6beb0f4c ONLINE
gptid/4b0e62b1-3da1-11ed-9ec7-ac1f6beb0f4c ONLINE
17610641027356593137 OFFLINE
gptid/b5105f23-4e42-11ed-a5f8-ac1f6beb0f4c ONLINE
gptid/4b245f4b-3da1-11ed-9ec7-ac1f6beb0f4c ONLINE
gptid/4b2c24c9-3da1-11ed-9ec7-ac1f6beb0f4c ONLINE
raidz1-3 ONLINE
gptid/2c8df258-3f7f-11ed-9ec7-ac1f6beb0f4c ONLINE
gptid/2cab60d9-3f7f-11ed-9ec7-ac1f6beb0f4c ONLINE
gptid/2c984c82-3f7f-11ed-9ec7-ac1f6beb0f4c ONLINE
gptid/2cc18a36-3f7f-11ed-9ec7-ac1f6beb0f4c ONLINE
gptid/2c80e634-3f7f-11ed-9ec7-ac1f6beb0f4c ONLINE
gptid/2c92d50a-3f7f-11ed-9ec7-ac1f6beb0f4c ONLINE
logs
gptid/5e073063-3da2-11ed-9ec7-ac1f6beb0f4c ONLINE
gptid/5e0eb1c2-3da2-11ed-9ec7-ac1f6beb0f4c ONLINE
root@truenas[~]#
root@truenas[~]# glabel status
Name Status Components
gptid/0e2c39b5-4cf8-11ed-82b9-ac1f6beb0f4c N/A nvd2p2
gptid/5e073063-3da2-11ed-9ec7-ac1f6beb0f4c N/A nvd3p1
gptid/5e0eb1c2-3da2-11ed-9ec7-ac1f6beb0f4c N/A nvd4p1
gptid/0e25b610-4cf8-11ed-82b9-ac1f6beb0f4c N/A nvd5p2
gptid/0e5b01a8-4cf8-11ed-82b9-ac1f6beb0f4c N/A nvd6p2
gptid/0e1577dd-4cf8-11ed-82b9-ac1f6beb0f4c N/A nvd7p2
gptid/0e022865-4cf8-11ed-82b9-ac1f6beb0f4c N/A nvd8p2
gptid/0e21def1-4cf8-11ed-82b9-ac1f6beb0f4c N/A nvd9p2
gptid/e1aaf876-e47e-11ed-8ed0-a0423f4fad68 N/A ada2p1
gptid/e1b4c5b6-e47e-11ed-8ed0-a0423f4fad68 N/A ada2p2
gptid/824a5646-17b9-11ee-8d6e-7c10c93f4586 N/A ada6p1
gptid/2c92d50a-3f7f-11ed-9ec7-ac1f6beb0f4c N/A ada1p2
gptid/82418cf1-17b9-11ee-8d6e-7c10c93f4586 N/A ada5p1
gptid/9cfb0551-4dc0-11ed-a5f8-ac1f6beb0f4c N/A ada3p2
gptid/b5105f23-4e42-11ed-a5f8-ac1f6beb0f4c N/A da1p2
gptid/7f9c6e89-ee88-11ed-933a-a0423f4fad68 N/A ada0p2
gptid/4b0e62b1-3da1-11ed-9ec7-ac1f6beb0f4c N/A da4p2
gptid/4ad5382d-3da1-11ed-9ec7-ac1f6beb0f4c N/A da7p2
gptid/4b056d4d-3da1-11ed-9ec7-ac1f6beb0f4c N/A da0p2
gptid/2c984c82-3f7f-11ed-9ec7-ac1f6beb0f4c N/A ada4p2
gptid/4b2c24c9-3da1-11ed-9ec7-ac1f6beb0f4c N/A da8p2
gptid/2c80e634-3f7f-11ed-9ec7-ac1f6beb0f4c N/A da2p2
gptid/2cab60d9-3f7f-11ed-9ec7-ac1f6beb0f4c N/A da10p2
gptid/2c8df258-3f7f-11ed-9ec7-ac1f6beb0f4c N/A da3p2
gptid/2cc18a36-3f7f-11ed-9ec7-ac1f6beb0f4c N/A da9p2
gptid/4b245f4b-3da1-11ed-9ec7-ac1f6beb0f4c N/A da6p2
gptid/4ade9261-3da1-11ed-9ec7-ac1f6beb0f4c N/A da6p1
gptid/2c7726d2-3f7f-11ed-9ec7-ac1f6beb0f4c N/A da9p1
gptid/2c3260d7-3f7f-11ed-9ec7-ac1f6beb0f4c N/A da3p1
gptid/2c2a32c1-3f7f-11ed-9ec7-ac1f6beb0f4c N/A da10p1
gptid/2c19e658-3f7f-11ed-9ec7-ac1f6beb0f4c N/A da2p1
gptid/4aca117b-3da1-11ed-9ec7-ac1f6beb0f4c N/A da8p1
gptid/2c41d9ab-3f7f-11ed-9ec7-ac1f6beb0f4c N/A ada4p1
gptid/4ab6f97a-3da1-11ed-9ec7-ac1f6beb0f4c N/A da0p1
gptid/4a990ac9-3da1-11ed-9ec7-ac1f6beb0f4c N/A da7p1
gptid/4aadde14-3da1-11ed-9ec7-ac1f6beb0f4c N/A da4p1
gptid/7f842405-ee88-11ed-933a-a0423f4fad68 N/A ada0p1
gptid/b4f01713-4e42-11ed-a5f8-ac1f6beb0f4c N/A da1p1
gptid/9cf603eb-4dc0-11ed-a5f8-ac1f6beb0f4c N/A ada3p1
gptid/2c4e4fa1-3f7f-11ed-9ec7-ac1f6beb0f4c N/A ada1p1
gptid/e1b00daf-e47e-11ed-8ed0-a0423f4fad68 N/A ada2p3
Not sure how to figure the physical serial number for the offline drive
Still not sure how correlate this output to the physical drive
root@truenas[~]# zdb -l /dev/ada0p2
LABEL 0
version: 5000
state: 0
txg: 1867430
pool_guid: 13392335571467977791
errata: 0
hostid: 2561052841
hostname: ''
top_guid: 13483495543322532732
guid: 17610641027356593137
vdev_children: 5
vdev_tree:
type: 'raidz'
nparity: 1
metaslab_array: 137
metaslab_shift: 34
ashift: 12
asize: 55995876507648
is_log: 0
create_txg: 4
children[0]:
type: 'disk'
guid: 6699077973069220370
path: '/dev/gptid/4b056d4d-3da1-11ed-9ec7-ac1f6beb0f4c'
phys_path: 'id1,enc@n510600b00fde7dc0/type@0/slot@9/p2'
DTL: 594
create_txg: 4
children[1]:
type: 'disk'
guid: 17202868484204630429
path: '/dev/gptid/4ad5382d-3da1-11ed-9ec7-ac1f6beb0f4c'
phys_path: 'id1,enc@n510600b00fde7dc0/type@0/slot@2/p2'
DTL: 593
create_txg: 4
children[2]:
type: 'disk'
guid: 5997615711680594197
path: '/dev/gptid/4b0e62b1-3da1-11ed-9ec7-ac1f6beb0f4c'
phys_path: 'id1,enc@n510600b00fde7dc0/type@0/slot@10/p2'
DTL: 592
create_txg: 4
children[3]:
type: 'disk'
path: '/dev/da9p2'
phys_path: 'id1,enc@n510600b00fde7dc0/type@0/slot@8/p2'
DTL: 591
create_txg: 4
children[4]:
type: 'disk'
guid: 12818104095896987338
path: '/dev/gptid/b5105f23-4e42-11ed-a5f8-ac1f6beb0f4c'
phys_path: 'id1,enc@n510600b00fde7dc0/type@0/slot@a/p2'
DTL: 21341
create_txg: 4
children[5]:
type: 'disk'
guid: 8323995713329423129
path: '/dev/gptid/4b245f4b-3da1-11ed-9ec7-ac1f6beb0f4c'
DTL: 589
create_txg: 4
children[6]:
type: 'disk'
guid: 5909767864838000474
path: '/dev/gptid/4b2c24c9-3da1-11ed-9ec7-ac1f6beb0f4c'
phys_path: 'id1,enc@n510600b00fde7dc0/type@0/slot@4/p2'
DTL: 588
create_txg: 4
If your drives have activity lights, you can go from identifier to light with dd if=/dev/da4 of=/dev/null bs=1024k count=5000
For importing, have you tried with the -f flag yet?
I tried varying combinations of zpool import -f -F -m -X Poolname
with what result? (clearly not an imported pool it seems, but other output may have provided some clues)
I note that the pool is showing as "corrupted data" at this point.
What's your hardware setup?
The pool is currently in a Ryzen build and leverages a LSI 9300-16i HBA for connection to all drives. All 14 drives in pool show up in GUI but for some reason I cant figure out what drive is reporting as offline to try to remediate.
boot-pool ONLINE
mirror-0 ONLINE
gptid/e1a67a36-e47e-11ed-8ed0-a0423f4fad68 ONLINE
gptid/e1b4c5b6-e47e-11ed-8ed0-a0423f4fad68 ONLINE
state: FAULTED
the '-f' flag.
raidz1-0 DEGRADED
raidz1-3 ONLINE
gptid/9cfb0551-4dc0-11ed-a5f8-ac1f6beb0f4c ONLINE
root@truenas[~]# zpool import -f -F -m NAPLES-SATA-RAIDZ-VOLUME
cannot import 'NAPLES-SATA-RAIDZ-VOLUME': one or more devices is currently unavailable
root@truenas[~]# zpool import -f -F -D -R /mnt NAPLES-SATA-RAIDZ-VOLUME
cannot import 'NAPLES-SATA-RAIDZ-VOLUME': no such pool available
root@truenas[~]# zpool import -f -FX NAPLES-SATA-RAIDZ-VOLUME -l
