Recover data from HDD with pool
raynaud
Saludos, actualmente tengo montado TrueNas en proxmox, añadi para efectos de prueba un disco dudo virtual de 300gb para PLEX, que posteriomente añadi un disco duro fisico nuevo, para lo cual copie este disco de 300 en la unidad nuevo y la extendi para tener 5T.
Todo excelente hasta este punto, el problema es que sincronize una cuenta de Drive y me borro algunas carpetas.
Tengo agregado el disco duro anterior para ver si puedo sacar la info y moverla al nuevo, pero TrueNas no me permite ni importar el pool ni el disco, pero si lo reconoce, ya intente con zpool import, import pool desde la gui, pero no he consegido acceder al disco duro, que me recomiendan?.
The name pool and configuration of this is the same, beacuse is a copy and extend of virtual disk
raynaud
Greetings, I currently have TrueNas mounted on proxmox, I added a 300gb virtual hard drive for PLEX for testing purposes, which I later added a new physical hard drive, for which I copied this 300gb drive into the new unit and extended it to have 5T .
Everything great up to this point, the problem is that I sync a Drive account and I delete some folders.
I have added the previous hard drive to see if I can get the information and move it to the new one, but TrueNas does not allow me to import the pool or the disk, but if it recognizes it, I already tried with zpool import, import pool from the gui, but no I have managed to access the hard drive, what do you recommend?
