victorhooi
- Mar 16, 2012
What's the recommended way to setup NextCloud on TrueNAS SCALE currently?
Should you use Docker, or VMs? Or some other method?
And how do you link it up to the TrueNAS SCALE storage? (I saw that NextCloud has an external storage feature, which lets you mount SMB/CIFS shares - could you do it that way? Or is there a more efficient/robust way, since TrueNAS SCALE and NextCloud are on the same host?).
Thanks,
Victor
Thanks,
Victor
