Daisuke
- Jun 23, 2011
But 750euro = 1000+$ USD :DActually I found a DS710+ less than 450 €, with 2*WESTERN DIGITAL - Caviar Green Power 3 Tb Sata III 6 Gb / s buffer 64 Mb 7200 rpm at 132 € each I will have a NAS with less than 750,00 € and a LAN RAID 1 continuos transfer rate little less than 95 MB/s on a Gigabit LAN capable of a theorical 125 MB/s maximum transfer rate.
I am perfectly in accordance with you if you say that I can not upgrade this system but, considering that the FreeNAS 8 version is still without iTunes server or Emule download capability and considering that this system has to be configured (and I am completely a newbie in FreeeNAS) I am not sure if I will reach the same performance and the same usability targets than a branded NAS.
This is my point.
Which is your transfer rate with your monsterNAS?
I am of course available to discuss and to change my above mentioned statements.
You should get easy 300+MB/sec with fairly old hardware. :)
In the video, he is using 4 WD20EARS on hardware RAID5. When 8.0.1 is released, I will try it both ways (hardware and software RAID) and see what performs better as my mobo has a hardware raid controller.
If I perform a full installation (i.e. in a dedicated small HD) is it possible to upgrade to FreeNAS 8 without lose data or configurations?
There is no upgrade from 7 to 8, the devs are working on it. You should start with 8.0.1 beta4, it supports upgrades through webGUI. Anything less, you will have to a clean install when you move to 8.0.1 version.
