Greetings All,
I have come across a Dell T30 which I know are popular with newbie FreeNAS users. These come with 8GB of ECC memory installed. I'm attempting to find the proper memory to add to it. I have found this memory on Amazon which several commenters have said is a good fit for the T30.
Kingston Technology ValueRAM 16GB 2400MHz DDR4 ECC CL17 DIMM 2Rx8 Desktop Memory (KVR24E17D8/16)
https://www.amazon.com/dp/B01FM3GBC...olid=2IMD7UPD5XGUY&psc=0&ref_=lv_ov_lig_dp_it
However, Amazon has one of those "Newer model" links pointing to this memory:
Kingston KSM24ED8/16ME Server Premier - DDR4-16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - CL17-1.2 V - unbuffered - ECC
https://www.amazon.com/Kingston-KSM24ED8-16ME-Server-Premier/dp/B07BGFXV62/ref=dp_ob_title_ce
Does anyone know if this second one will work, considering it's $50 cheaper? And I believe both of these options are 2 sticks (8GB each). Can I just drop these in with the existing memory? I didn't know if it's ok to have 3 8GB sticks or is it better to install memory in pairs?
