Thanks for the reply, not sure what you mean by nested virtualization? I just want the debian VM's to close down gracefully if the Truenas scale bare metal receives a shutdown command?
Best to describe what steps you took and what the result was,
<channel type='unix'> <source mode='bind' path='/var/lib/libvirt/qemu/f16x86_64.agent'/> <target type='virtio' name='org.qemu.guest_agent.0'/> </channel>
/usr/bin/virsh -c "qemu+unix:///system?socket=/run/truenas_libvirt/libvirt-sock" attach-device 1_debian --file /mnt/nvme/vm/channel.xml --current
virsh command is successfulDevice attached successfully
virsh command failserror: Failed to attach device from /mnt/nvme/vm/channel.xml error: internal error: no virtio-serial controllers are available
virsh is successful, I can ssh into the VM and start the qemu-gasystemctl start qemu-guest-agent.service
systemctl status qemu-guest-agent.service
● qemu-guest-agent.service - QEMU Guest Agent
Loaded: loaded (/lib/systemd/system/qemu-guest-agent.service; static)
Active: active (running) since Thu 2022-12-29 07:57:32 EST; 55s ago
Main PID: 444 (qemu-ga)
Tasks: 2 (limit: 4671)
Memory: 2.2M
CPU: 5ms
CGroup: /system.slice/qemu-guest-agent.service
└─444 /usr/sbin/qemu-ga
Dec 29 07:57:32 debian systemd[1]: Started QEMU Guest Agent.
So on 22.12 we are stuck?
-chardev spicevmc,id=charchannel0,name=vdagent \ -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 \
no virtio-serial controllers are available I started connecting dots.error: Operation not supported: 'virtio-serial' controller cannot be hot plugged.nano /usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/domain_xml.py
not as shown below
if not spice_server_available:
systemctl restart middlewared.service
virsh command is now successful and I can start the qemu-ga inside my VM on SCALE 22.12.0Ok... lots of back and forth between releases... compare this / compare that... Probably would have been so much quicker for some who actually knows what they are doingAnyways a few hours of staring at this and here's where I'm at.
I dumped my VM logs from both versions of SCALE. Here is what I'm guessing is the important part
On SCALE 22.02.04 I see these lines in my VM log (among others)
Code:-chardev spicevmc,id=charchannel0,name=vdagent \ -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 \
However, these lines were missing from the VM logs on SCALE 22.12.0
Looking again at the error messageno virtio-serial controllers are availableI started connecting dots.
Using the same approach mentioned on reddit, I tried creating another xml file to try and define / attach a virtio-serial - The contents of my file is irrelevant anywayserror: Operation not supported: 'virtio-serial' controller cannot be hot plugged.
I'm not sure what the correct way is to add a virtio-serial controller on TrueNAS - So I had a really bad idea, why not dig around in the code to see if I could make it work?! Somehow I managed to get it working (sort of) without destroying my NAS.
Eventually I figured out that changing the display type from VNC to SPICE will create a virtio-serial controller on SCALE 22.12.0. With that, I can now get qemu-guest-agent running again, using this solution I mentioned above
This was the first (horrible) idea I tried (but it works using display type VNC)
Code:nano /usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/domain_xml.py
Edit line 171 - addnotas shown below
Code:if not spice_server_available:
Save changes and exit editor, then restart middleware
Code:systemctl restart middlewared.service
Now after I restart my VM and check the logs, it includes
and thevirshcommand is now successful and I can start the qemu-ga inside my VM on SCALE 22.12.0
I'd suggest reporting this as a bug
agent.xml makes sense to me.agent.xml<channel type='unix'> <target type='virtio' name='org.qemu.guest_agent.0'/> </channel>
start-haos.sh#!/bin/bash
## Enter the alphanumeric name you used for your VM
vm='HomeAssistant'
## Set a full path to the agent xml file you created
agent_xml='/mnt/tank/vm/agent.xml'
set -euo pipefail
if [ ${EUID} -ne 0 ]; then
echo "please run this script as root or using sudo"
elif [ ! -f "${agent_xml}" ]; then
echo "agent_xml not found: ${agent_xml}"
else
id=$(/usr/bin/midclt call vm.query | /usr/bin/jq -r '.[] | ( .id|tostring ) + ":" + .name' | /usr/bin/grep "${vm}" | /usr/bin/cut -f1 -d':')
/usr/bin/midclt call vm.start "${id}"
sleep 1
name=$(/usr/bin/virsh -c "qemu+unix:///system?socket=/run/truenas_libvirt/libvirt-sock" list --name | /usr/bin/grep "${vm}")
/usr/bin/virsh -c "qemu+unix:///system?socket=/run/truenas_libvirt/libvirt-sock" attach-device "${name}" "${agent_xml}"
fi
#!/bin/bash
## Set the name of your VM
vm='HomeAssistant'
echo "Please run this script as root or using sudo"
exit 1
fi
set -euo pipefail
# create a temporary XML file for the QEMU guest agent
guest_agent=$(mktemp -t agent.xml.XXXXX)
cat << END_XML > "${guest_agent}"
</channel>
END_XML
# get id and use it to start the VM
/usr/bin/midclt call vm.start "${id}" &> /dev/null
sleep 1
# get VM name and use it to attach the QEMU guest agent
/usr/bin/virsh -c "qemu+unix:///system?socket=/run/truenas_libvirt/libvirt-sock" attach-device "${name}" "${guest_agent}"
# remove the temporary XML file
rm "${guest_agent}"
--- /usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/domain_xml.py.orig 2022-12-13 06:32:23.000000000 -0600
+++ /usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/domain_xml.py 2022-12-31 22:29:48.212387984 -0600
@@ -168,14 +168,20 @@
# default if not all headless servers like ubuntu etc require it to boot
devices.append(create_element('video'))
- if spice_server_available:
- # We always add spicevmc channel device when a spice display device is available to allow users
- # to install guest agents for improved vm experience
- devices.append(create_element(
- 'channel', type='spicevmc', attribute_dict={
- 'children': [create_element('target', type='virtio', name='com.redhat.spice.0')]
+ # We always add spicevmc channel device to allow users
+ # to install guest agents for improved vm experience
+ devices.append(create_element(
+ 'channel', type='spicevmc', attribute_dict={
+ 'children': [create_element('target', type='virtio', name='com.redhat.spice.0')]
+ 'channel', type='unix', attribute_dict={
+ 'children': [create_element('source', mode='bind', path='/var/lib/libvirt/qemu/f16x86_64.agent'),
+ create_element('target', type='virtio', name='org.qemu.guest_agent.0'),
devices.append(create_element('serial', type='pty'))
return create_element('devices', attribute_dict={'children': devices})
How do you mean you 'patched' the middleware, how do I do that? and is it allowed to do such a thing, does it have any side effects on future official patches?Fantastic thread! On my TrueNAS 22.12, I fixed the problem by patching the middleware instead (apply the patch below, restart middlewared). This way, I don't have to select VMs or rely on restart scripts and I can still use VNC.
I also learned that TrueNAS supports the ptp_kvm module (see for example Time sync KVM guest on Debian on how to use it on chrony) for better time synchronization. But ONLY when the number of CPUs is set to 1 with multiple cores, rather than multiple CPUs with one core each.
Code:--- /usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/domain_xml.py.orig 2022-12-13 06:32:23.000000000 -0600 +++ /usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/domain_xml.py 2022-12-31 22:29:48.212387984 -0600 @@ -168,14 +168,20 @@ # default if not all headless servers like ubuntu etc require it to boot devices.append(create_element('video')) - if spice_server_available: - # We always add spicevmc channel device when a spice display device is available to allow users - # to install guest agents for improved vm experience - devices.append(create_element( - 'channel', type='spicevmc', attribute_dict={ - 'children': [create_element('target', type='virtio', name='com.redhat.spice.0')] - } - )) + # We always add spicevmc channel device to allow users + # to install guest agents for improved vm experience + devices.append(create_element( + 'channel', type='spicevmc', attribute_dict={ + 'children': [create_element('target', type='virtio', name='com.redhat.spice.0')] + } + )) + devices.append(create_element( + 'channel', type='unix', attribute_dict={ + 'children': [create_element('source', mode='bind', path='/var/lib/libvirt/qemu/f16x86_64.agent'), + create_element('target', type='virtio', name='org.qemu.guest_agent.0'), + ] + } + )) devices.append(create_element('serial', type='pty')) return create_element('devices', attribute_dict={'children': devices})
They basically mean that they simply modified the python script that controls this behavior.How do you mean you 'patched' the middleware, how do I do that? and is it allowed to do such a thing, does it have any side effects on future official patches?
As for how it affects updates
Ok have upvoted the issue (as I started the thread LoL) If anyone has time to document how i make and apply this patch that would be great, I am very new to Scale, but not to debian........They basically mean that they simply modified the python script that controls this behavior.
What they're provided is a "patch" or diff file that contains only the differences between the original version of the file and their offsets.
You can use it with the 'patch' "command to apply these same changes to your copy of the file. First, you'd want to make a copy of the original as a backup.
As for if you can do this:
For certain doing this is not supported, as in if you ask for help with problems related to VM setup and its discovered you made this change, those helping you might get quite annoyed and stopping helping you. At least in an official capacity; however, this is a relatively minor patch and probably works fairly well (I will try it myself soon) given @rmr likely wouldn't use it if it completely bricked their VMs. So I would worry terribly about it.
As for how it affects updates:
I don't know exactly how SCALE implements updates so I can't be sure. If the updates themselves make use of patches, such that existing files are modified into the new ones, then yes this would break if that file gets changed in the updated. If the updates simply copy in the new files, overwriting old ones, then no it wouldn't be an issue. The way to be absolutely safe about it would be to restore the original backup before performing any updates down the road.
I will say though, if this is functionality you'd like to see in SCALE by default (which I figured would be anyway given how annoying this issue is at the moment) I'd ask that you upvote the issue that @tprelo created on Jira about this so that there a better chance it gets addressed in a future update.
Ah yes, good point. I wasn't thinking about that originally.Future updates should just overwrite your manual changes.
If the issue is not addressed, you will need to apply the "patch" again after updates
Woops, sorry I missed that.Ok have upvoted the issue (as I started the thread LoL) If anyone has time to document how i make and apply this patch that would be great, I am very new to Scale, but not to debian........
curl https://www.truenas.com/community/attachments/middlware-qemu-ga-txt.62022/ --output middlware-qemu-ga.patch
patch -b -d/ -p0 < middleware-qemu-ga.patch
when applying the patch.patch unexpectedly ends in middle of line
Hunk #1 succeeded at 168 with fuzz 1.
