Qbittorrent, how to create a torrent?
diskdiddler
The option under tools create a torrent is missing. If you google a guide on how to make a torrent, with qbittorrent, it clearly shows menu options which do not exist in it under FreeNAS
I've followed the how-to guide for QBit and it's otherwise working fine, although it seems tuck at an older version
The how-to thread is deceased btw, has been for near a year, no amount of 'hello, anyone please' will revive it
diskdiddler
No, at this point, I have no idea how to actually create a torrent with the program, since the option is missing
D
dlavigne
Guest
If you manually install qbittorrent in a jail, does it provide the missing menu options? This will help us determine if the issue is with the FreeBSD port or the plugin itself.
