So I have been looking for days now for solution. I really hope I have not missed it, if so I am sorry.
I got one torrent working couple of days ago, downloaded 100%, but the other did not work.
.torrent file work on other machines.
The setup:
intel i5, 64gb ram DDR4. Two pools, first is 2x8TB and second is 3x1TB.
TrueNAS-SCALE-23.10.1
qBittorent v4.6.2 web ui
Part from adding and "mounting" a dir in APPS/EDIT --> Storage and Persistence --> Additional App Storage I do not change anything.
Enabled = yes | CHOWN and CHMOD 775 = yes | mount path in pool excist and for the symlink I choose an easy one ( /downloads ).
Tested with both link and file. Start up most of the time up to 5mb/s then fast down to 0 b/s and red mark beside and text Errored. I have reviewed the log file for qBittorrent but it is emty.
I should mention that the SCALE system seems much more instable than CORE i ran before. Often that Apps stop at 25 % or keep showing "Deeploying" for ages. To that edge so that I actually deleted the ix folder once and created a new one in apps GUI again. That atleast fixed some speed/crash issues. But the above qBit remains :(
Any thoughts and/or solutions?
Thanks
The setup:
Thanks
