Joshua Parker Ruehlig
- Dec 5, 2011
I don't know what you're trying to show me, that the config file already has stuff in it? in this case you replace it everything. there's probably a way to delete a line at a time, I don't know with that editor though.ohh haha i thougt i nbeed to open it. but i didnt know not with show haha
so no i have opened like you said and ehmm.. check that out XD : http://pastebin.com/k0vnP7qi
seems i am doing somthing wrong. have some errors
so maybe i do a full fresh install of the freenas on my virtualbox so i can do it from begining new?
your going to reinstall the OS from scratch?! why? that's wouldn't change anything, the config file would always exists. also, that's what jails are for. if you really needed to start over just create a new jail and try again.
finally you're running freenas on virtual box? I don't even know if that's supported. I always run it on bare metal.
