The guide for `Prowlarr` should now be on the official *arr wiki. I will look into getting a note added about requiring the AppData being in a different place than the Startup and/or bug the maintainer about changing the default :)
There is already a patch that is waiting for merge that will 1) disable the updater and 2) make sure appdata and startup are different (unless set different by user then its up to you)
