This is my third time rebuilding my server after some hardware failures. I have 18TB raid 5 storage that should have all the data on them from before. I have imported the data and now when I go to add the jail I'm unsure where to point the root to. When I browse the files are as follows:
mnt
>mediastorage
>>Plexserver
>>>media
>>>plexuser
>>>guest
>>>plex
>>PlexonFreenas
>>Pluginjails
>>>plexmediaserver_1
Under plex and plexmediaserver_1 there are a bunch of standard folders. I don't know what I did when I installed the second time but I'm not sure if I ever setup FreeNAS properly in the first place. I used to have a problem with windows not being able to see the connection but the GUI would still work, after a while the GUI would stop working and I would have to hard reboot the system to get it to work. I would love some hand holding to make sure I have this setup correctly but that may be too much to ask.
Thank you all for your help.
mnt
>mediastorage
>>Plexserver
>>>media
>>>plexuser
>>>guest
>>>plex
>>PlexonFreenas
>>Pluginjails
>>>plexmediaserver_1
