Device Model:     WDC WD100EMAZ-00WJTA0
LU WWN Device Id: 5 000cca 267c84a01
Firmware Version: 83.H0A83
User Capacity:    10,000,831,348,736 bytes [10.0 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Wed Jul 12 13:09:29 2023 MST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (   93) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (1132) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0004   130   130   054    Old_age   Offline      -       108
  3 Spin_Up_Time            0x0007   149   149   024    Pre-fail  Always       -       448 (Average 437)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       65
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000a   100   100   067    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0004   128   128   020    Old_age   Offline      -       18
  9 Power_On_Hours          0x0012   095   095   000    Old_age   Always       -       37332
 10 Spin_Retry_Count        0x0012   100   100   060    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       65
 22 Unknown_Attribute       0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       1577
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       1577
194 Temperature_Celsius     0x0002   135   135   000    Old_age   Always       -       48 (Min/Max 23/53)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%     37330         -
# 2  Extended offline    Completed without error       00%       377         -
# 3  Extended offline    Completed without error       00%       209         -
# 4  Short offline       Completed without error       00%         0         -
LU WWN Device Id: 5 000cca 267c7f7ae
Local Time is:    Wed Jul 12 13:10:04 2023 MST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1048) minutes.
  2 Throughput_Performance  0x0004   131   131   054    Old_age   Offline      -       104
  3 Spin_Up_Time            0x0007   148   148   024    Pre-fail  Always       -       438 (Average 448)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       92
  9 Power_On_Hours          0x0012   095   095   000    Old_age   Always       -       37298
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       90
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       1613
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       1613
194 Temperature_Celsius     0x0002   138   138   000    Old_age   Always       -       47 (Min/Max 22/52)
No Errors Logged
# 1  Extended offline    Completed without error       00%     37297         -
# 2  Extended offline    Completed without error       00%       343         -
# 3  Extended offline    Completed without error       00%       176         -
LU WWN Device Id: 5 000cca 267caaea7
Local Time is:    Wed Jul 12 13:10:34 2023 MST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1125) minutes.
  3 Spin_Up_Time            0x0007   148   148   024    Pre-fail  Always       -       439 (Average 451)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       33
  9 Power_On_Hours          0x0012   095   095   000    Old_age   Always       -       36916
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       32
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       1533
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       1533
194 Temperature_Celsius     0x0002   138   138   000    Old_age   Always       -       47 (Min/Max 24/51)
No Errors Logged
# 1  Extended offline    Completed without error       00%     36913         -
LU WWN Device Id: 5 000cca 267cc21e0
Local Time is:    Wed Jul 12 13:10:52 2023 MST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1131) minutes.
  3 Spin_Up_Time            0x0007   253   253   024    Pre-fail  Always       -       89 (Average 123)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       81
  9 Power_On_Hours          0x0012   095   095   000    Old_age   Always       -       36915
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       80
192 Power-Off_Retract_Count 0x0032   098   098   000    Old_age   Always       -       3452
193 Load_Cycle_Count        0x0012   098   098   000    Old_age   Always       -       3452
194 Temperature_Celsius     0x0002   147   147   000    Old_age   Always       -       44 (Min/Max 24/51)
No Errors Logged
LU WWN Device Id: 5 000cca 267c878a1
Local Time is:    Wed Jul 12 13:11:26 2023 MST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1199) minutes.
  2 Throughput_Performance  0x0004   130   130   054    Old_age   Offline      -       110
  3 Spin_Up_Time            0x0007   153   153   024    Pre-fail  Always       -       435 (Average 425)
  9 Power_On_Hours          0x0012   095   095   000    Old_age   Always       -       37232
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       64
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       1584
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       1584
194 Temperature_Celsius     0x0002   144   144   000    Old_age   Always       -       45 (Min/Max 23/52)
No Errors Logged
# 1  Extended offline    Completed without error       00%     37230         -
# 2  Extended offline    Completed without error       00%       277         -
# 3  Extended offline    Completed without error       00%       109         -
LU WWN Device Id: 5 000cca 267c85b4d
Local Time is:    Wed Jul 12 13:11:34 2023 MST
  2 Throughput_Performance  0x0004   129   129   054    Old_age   Offline      -       112
  3 Spin_Up_Time            0x0007   151   151   024    Pre-fail  Always       -       429 (Average 443)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       47
  9 Power_On_Hours          0x0012   095   095   000    Old_age   Always       -       37429
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       47
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       1569
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       1569
194 Temperature_Celsius     0x0002   138   138   000    Old_age   Always       -       47 (Min/Max 23/52)
No Errors Logged
# 1  Extended offline    Completed without error       00%     37427         -
# 2  Extended offline    Completed without error       00%       475         -
# 3  Extended offline    Completed without error       00%       307         -
