jgreco
Resident Grinch
- May 29, 2011
I'd like to add a detail to the excellent OP:
Approve of the updates to the OP?
Looks good, thanks for the writeup.Approve of the updates to the OP?
You found a non-rackmount chassis that holds 20 drives? That just strikes me as a bad idea (especially for cooling) but then again I work mostly with rackmount gear, so you can disregard my bias. :)
For a large system, you probably don't want to follow my sizing math outlined above, because it rapidly gets untenable above 12 drives (arguably even at 12 drives). I don't have particular recommendations beyond that point, because even the Seasonic recommendation isn't truly mine, but rather that of many happy forum users plus my eyeballing of a bunch of reviews.
My best guess is that you could very well still be fine with a ~900W quality power supply. We used to sell 950W PSU's that powered 24-drive systems which peaked at 6.6A (792W) but that was back in the days of 250GB SATA disks. More recent arrays are still generally in that ballpark. The difference is that we're actively measuring this stuff as we build systems, and have the tools to do so. I am ... very nervous ... about making recommendations that are not provably reasonable on a mathematical basis. However, I do encourage you to read every word I've written, and then to look at the 45Drives data above (bearing in mind that's drives ONLY), to make some educated guesses as to power requirements. A lot of this business is just doing research, then doing your homework, and understanding the realities.
both of which imply that you need instrumentation not readily available to the average guy-at-home.
One open question is still: Is the Seasonic X, and Platinum series similary recommended compared to the G series? Should I prefer one of them?
Hum... in fact if you just want to know the current peak on the 12 V + 5 V rails (because of the very simple circuit we can't see one current at a time but I think it's ok for what we want to know) then all you need is a molex/SATA adapter, a resistor, a diode, an Op-Amp, a capacitor and a DMM (even a crappy one at $5 would be OK if you don't already have one) so the total budget should be under $15 which is very reasonable I think :)
I'll draw a schematic if someone is interested ;)
Yhey are better than the G series, so yes, you should prefer them ;)
Hum... in fact if you just want to know the current peak on the 12 V + 5 V rails (because of the very simple circuit we can't see one current at a time but I think it's ok for what we want to know) then all you need is a molex/SATA adapter, 3 resistors, 2 diodes, an Op-Amp, a capacitor and a DMM (even a crappy one at $5 would be OK if you don't already have one) so the total budget should be under $15 which is very reasonable I think :)
I wanted to know if I should prefer eg. Platinum over X-series.
Ok, I'll even test the circuit to be sure it works ;)
I give one like for who can find why you need the CAT5 cable... :D
You mean in addition to wires connecting stuff on the breadboard?I give one like for who can find why you need the CAT5 cable... :D
To tie up the mad scientist in the room that is hungrily looking at our NAS boxes, duh.
Does it have to be copper twisted pair, or is the Cat. 5 part just what you had at hand?
