Problems with SAS SSD on TrueNas Scale 22.12.1
RodrigoLopes
Hello all,
I managed to get my hand on used Enterprise SAS SSD and decided to replace my "OLD" SAS HDD.
After replacing all the disks i started seeing the following messages on the LOGs:
Feb 26 22:55:10 home-nas kernel: sd 0:0:0:0: [sda] tag#2593 Sense Key : Recovered Error [current]
Feb 26 22:55:10 home-nas kernel: sd 0:0:0:0: [sda] tag#2593 Add. Sense: Defect list not found
Feb 26 22:55:10 home-nas kernel: sd 0:0:3:0: [sdd] tag#2616 Sense Key : Recovered Error [current]
Feb 26 22:55:10 home-nas kernel: sd 0:0:3:0: [sdd] tag#2616 Add. Sense: Defect list not found
Feb 26 22:55:10 home-nas kernel: sd 0:0:4:0: [sde] tag#2621 Sense Key : Recovered Error [current]
Feb 26 22:55:10 home-nas kernel: sd 0:0:4:0: [sde] tag#2621 Add. Sense: Defect list not found
Feb 26 22:55:10 home-nas kernel: sd 0:0:7:0: [sdh] tag#2565 Sense Key : Recovered Error [current] [descriptor]
Feb 26 22:55:10 home-nas kernel: sd 0:0:7:0: [sdh] tag#2565 Add. Sense: Defect list not found
Feb 26 22:55:10 home-nas kernel: sd 9:0:0:0: [sdi] tag#8337 Sense Key : Recovered Error [current]
Feb 26 22:55:10 home-nas kernel: sd 9:0:0:0: [sdi] tag#8337 Add. Sense: Defect list not found
Feb 26 22:55:10 home-nas kernel: sd 0:0:1:0: [sdb] tag#2560 Sense Key : Recovered Error [current] [descriptor]
Feb 26 22:55:10 home-nas kernel: sd 0:0:1:0: [sdb] tag#2560 Add. Sense: Defect list not found
Feb 26 22:55:10 home-nas kernel: sd 0:0:2:0: [sdc] tag#2563 Sense Key : Recovered Error [current] [descriptor]
Feb 26 22:55:10 home-nas kernel: sd 0:0:2:0: [sdc] tag#2563 Add. Sense: Defect list not found
Feb 26 22:55:10 home-nas kernel: sd 0:0:5:0: [sdf] tag#2566 Sense Key : Recovered Error [current] [descriptor]
Feb 26 22:55:10 home-nas kernel: sd 0:0:5:0: [sdf] tag#2566 Add. Sense: Defect list not found
Feb 26 22:55:10 home-nas kernel: sd 9:0:5:0: [sdn] tag#8411 Sense Key : Recovered Error [current]
Feb 26 22:55:10 home-nas kernel: sd 9:0:5:0: [sdn] tag#8411 Add. Sense: Defect list not found
At first i tought it could be because i installed SSDs with 12Gbps speed on a HBA that supports only 6Gbps but then i check that the "issue/error" is happening on the 6Gbps SSD. (i used to have 300GB SAS HDD with 12Gbps connections without any issues on the same cards.)
There are two types of disks:
  • SSD SAS 800GB 12Gbps (DELL SSD);
  • SSD SAS 1.6TB 6Gbps (DELL SSD)
The HBA i have installed are the following:
  • Dell PERC H310 SAS SATA Controller IT-Mode;
  • LSI HBA 9217-8i IT Mode;
The rest of the hardware is the following: (also present on the signature bellow)
  • Board:
    • MSI B450M MORTAR MAX (latest BIOS of 2022-08-11)
  • CPU:
    • AMD Ryzen 3 2200G Quad-Core 3.5GHz c/ Turbo 3.7GHz
  • Memory:
    • HyperX Fury Memória RAM ‎DDR4 SDRAM ‎2666 MHz [4*8GB - 32GB] NON-ECC
  • PSU:
    • Corsair 550W 80 PLUS Gold Semi Modular
  • Boot Disk:
    • 2 x Intel SSD DC S3510 Series - 120GB [SATA 6Gbps]
And yes i don't have ECC memory, this NAS server is for home use mostly and for a small lab enviorment. The cost to implement a board, CPU and memmory to support ECC wasn't worth it. Data integrity won't be an issue since i have backups of all the critical data outside this enviorment.
Thanks in advance for the help.
Regards,
Rodrigo Lopes
VR46
I am getting similar messages even on a disk I just put in to replace another and is not in a pool yet. Seems to only be SAS SSD and not SATA SSD.
RodrigoLopes
True that's mostly happening on my DELL SSD SAS disk.
I have Intel SATA SSDs that don't report this error.
Already update the TrueNas and the message keeps showing up.
Tried checking if there is any new upgrades to both LSIs i have installed but they are running the latest version too.
