Problems with P420 HBA mode
Samuel Tai
Do i havte to passtrought the HBA?
Yes, please passthrough the entire HBA, not individual disks. That explains why you're not seeing all SMART data.
f!ReW4LL
i dont see it anyway :(
Samuel Tai
Does smartctl -a /dev/da2 show any temperature data? The graph often lags, until it's received enough data.
f!ReW4LL
Model Family: Seagate IronWolf
Device Model: ST8000VN004-2M2101
Serial Number: WSD07KZB
LU WWN Device Id: 5 000c50 0d4ee1c9c
Firmware Version: SC60
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Mar 18 21:40:35 2021 CET
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 559) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 711) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 076 064 044 Pre-fail Always - 38611577
3 Spin_Up_Time 0x0003 082 081 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 83
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 072 060 045 Pre-fail Always - 16012118
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 926
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 84
18 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 073 022 040 Old_age Always In_the_past 27 (1 165 28 27 0)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 45
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 418
194 Temperature_Celsius 0x0022 027 078 000 Old_age Always - 27 (0 18 0 0 0)
195 Hardware_ECC_Recovered 0x001a 076 064 000 Old_age Always - 38611577
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 810 (25 120 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 8735432206
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 36444895286
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Samuel Tai
You're getting temp data from the disk.
Samuel Tai
Give it 24 hours. It takes time for the RRD counters to catch up.
