SOLVED Problems when installing TrueCharts catalog
Hello all,
I have been using TrueCharts for quite a long time now. I just wanted to re-install it for some reason but upon re-installing it, it gave me an error saying "Error: [EFAULT] Catalog was added successfully but failed to sync: [EFAULT] Invalid operation: ==" I really don't understand how and why. I really need urgent help as I need to install Tautulli. It keeps on trying to sync to the catalog but fails.
Thank You
Ashvath Sridharan
Specs:
OS: TrueNAS Scale Angelfish 22.02.4
CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz 2 Cores
RAM: 8GB RAM Dual Channel
HDD: 1x2TB WD Surveillance, 1x320GB Seagate HDD, 1x1TB Seagate, 1x500GB Seagate
MOBO: Dell Optiplex 3010MT Original
Networking: Realtek 1Gbps Integrated Card
anodos
Sambassador
Hello all,
Thank You
Ashvath Sridharan
Specs:
That looks like a usage error for our filtering APIs. Can you get fully traceback from /var/log/middlewared.log?
ksimm1
Hello all,
You're still on angelfish. you need to update scale to bluefin
Will it give any problems? When I was in TrueNAS Core, I updated it to a better version of it but I faced many issues
Update: I have updated my systems to bluefin and installed Truecharts catalog and it WORKED! Thank you so much for helping me! The only problem I faced was when the applications weren't loading, just did a restart and it came back!
