Problem updating from 11.1 Stable to 11.2 Release.
I'm looking for a bit of advice, I tried to update from 12.1 Stable to 12.2 Release tonight and it's dumped me at the command prompt with the following message. Thankfully I've downloaded the config file, so I can in theory update using a usb stick and re-apply my setup.
Current Hardware
  1. Supermicro X11SSL-F-O
  2. Intel Core i3-6300
  3. 32Gig DDR4
  4. Seasonic G550 550W 80+ Gold Certified PSU
  5. 4 x Western Digital Red 3TB
  6. 2 x SanDisk Ultra Fit 16GB USB 3.0 Flash Drive
Any help greatly appreciated.
Chris Moore
Chris Moore
PS. You should be able to go back to the previous boot environment without needing to reinstall anything.
Chris Moore
PSS. Please post back here with your ticket number.
I’ve rolled back to 11.1 Stable and will post my support ticket here tomorrow.
Thanks for the help Chris, appreciated.
