Problem starting smartd on boot, after boot via "Services" it works
Alex9779
Hi community,
I recently updated to 8.3.1 but I had that problem with 8.3.0 too.
I am running a FreeNAS with 5 HDs and one CF card. FreeNAS is on the CF.
My problem is as topic says that when I boot or reboot my NAS the smartd service is not started properly. I have following entries in my log:
Mar 21 01:12:08 nas02 smartd[4673]: Device: /dev/ada0, can't monitor Temperature, ignoring -W Directive
Mar 21 01:12:08 nas02 smartd[4673]: Unable to register ATA device /dev/ada0 at line 14 of file /usr/local/etc/smartd.conf
Mar 21 01:12:08 nas02 smartd[4673]: Unable to register device /dev/ada0 (no Directive -d removable). Exiting.
Mar 21 01:12:08 nas02 root: /etc/rc: WARNING: failed to start smartd
/dev/ada0 is the CF card...
When I then look into the services smart is marked as if it is started but ps tells me it is not. I have to "stop" it in services and then start it there again but then there is no error and it is starting...
What can I do about this?
I really want my system to be fully functional after a shutdown in case of power loss and the UPS going on low batt and repower.
Regards,
Alexander
ProtoSD
Did you try going to Storage->View Disks, and Edit ada0 and uncheck the SMART checkbox?
joeschmuck
Old Man
That is true, the boot flash drive does not show up under View Disks on my system.
So is your CF card connected to a SATA port? Maybe you could post a 'glabel status' here. Curious to see what it says.
Alex9779
Yes it is... The main board has 6 SATA ports. Fist one is the CF card ada0, 2 - 6 the hard drives ada1 - ada 5.
Out of 'glabel status' is:
Name  Status  Components
                             ufs/FreeNASs3     N/A  ada0s3
                             ufs/FreeNASs4     N/A  ada0s4
                    ufsid/50c8c7da3400b84f     N/A  ada0s1a
                            ufs/FreeNASs1a     N/A  ada0s1a
                            ufs/FreeNASs2a     N/A  ada0s2a
gptid/7a240c28-8f5b-11e2-9b5a-f46d04d898d3     N/A  ada1p2
gptid/24d575f3-8e96-11e2-91f9-f46d04d898d3     N/A  ada2p2
gptid/0870c326-6501-11e1-b9bd-f46d04d898d3     N/A  ada3p2
gptid/08ddeb79-6501-11e1-b9bd-f46d04d898d3     N/A  ada4p2
gptid/094e2ef1-6501-11e1-b9bd-f46d04d898d3     N/A  ada5p2
