Problem Installing Plugins/Jails
NetAdmin08
Every time I try installing a plugin the system becomes unresponsive and I have to force reboot, once rebooted the plugin is not installed but the jail is created. I have been able to install Plex, Transmission and Couchpotato but having trouble installing owncloud or any others.
Has anyone else seen this problem?
FreeNAS 9.2.1
Build FreeNAS-9.2.1-RELEASE-x64 (bd35c86)
Platform AMD A6-6400K APU with Radeon(tm) HD Graphics
Memory 7344MB
System Time Fri Feb 28 17:42:08 PST 2014
Uptime 5:42PM up 46 mins, 1 user
Load Average 1.23, 1.11, 0.63
D
dlavigne
Guest
By unresponsive do you mean that the system is freezing? If so, you need to figure out what is causing that.
Do you have a syslog dataset so that you can save the logs? If so, anything in /var/log/messages?
NetAdmin08
By non responsive I mean I lose access to all network connectivity.
I have created a syslog dataset and will post logs as soon as I have a chance to try installing the plugins again. Thanks for the tip.
Joshua Parker Ruehlig
9.2.1.what?
9.2.1 had problems and would reboot when creating a jail
NetAdmin08
Updated to 9.2.1.2, I am no longer having trouble installing plugins. Thanks Joshua for pointing out the flaw in 9.2.1
