Problem burning img to USB stick
andysilva
fuck i just used a cd to install it to the computer but i think i installed it to the 2tb drive. is this ok? how can i still use this for my files?
Per the manual... you don't. You reinstall to the proper media and then format the 2TB drive.
Remember what I said above...
Well, if prior users are any indication, if you can't figure out how to get the install correct you are really in for a nightmare when you try using FreeNAS. Chances of losing data later are quite high for people that aren't well educated and experienced in IT.
