Possible corruption.
Pasta
pool: vol1
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: none requested
NAME STATE READ WRITE CKSUM
vol1 ONLINE 0 0 3
mirror-0 ONLINE 0 0 6
gptid/8e246acc-d290-11e6-b4ae-0019b9443a54 ONLINE 0 0 6
gptid/8efb02e3-d290-11e6-b4ae-0019b9443a54 ONLINE 0 0 7
vol1/users@auto-20170106.1324-2w:<0x1e5>
I've had this FreeNAS server running for a while. I recently upgraded my pool to 2 WD Blue 1 TB drives, yes I know Red are best but this is what I could get my hands on. I was telling Windows to backup to a folder in vol1/users/backups. After that, I got the error posted above. I quickly ensured nothing on the NAS was critical and proceeded to test my vol1/users dataset as that is the region in which it appears is the corruption since it does not specify a file but what ever that is. Nothing in this dataset was any different from what it was before and everything was accessible without a problem, I moved files around. All nine yards. Everything was working as expected. However, this did give me a bit of a scare and I am wondering if there are any good cheap off-site backup solutions in which anyone might suggest me implementing.I saw in other threads were the CKSUM errors when corruption occurred was in the thousands. Based on that I'm not sure if this is something I should worry about and would appreciate any advice I could get. Thanks for reading, I could use any advice you've got.
If there is any extra info you guys need I should be here for the next hour off and on.
Jailer
Not strong, but bad
It looks like you have a corrupt snapshot. Did you burn in the drives before you put them in service? Do you have long and short smart tests set up on the drives?
Post the output of smartctl -a /dev/da0 and replace da0 with your drive numbers.
Pasta
I did not burn the drives. I am unaware of what that refers to. I do have long and short SMART tests. Daily short and weekly long.
ADA0 results
[root@freenas] ~# smartctl -a /dev/ada0
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Blue
Device Model: WDC WD10EZEX-08WN4A0
Serial Number: WD-WCC6Y7FJ4A7D
LU WWN Device Id: 5 0014ee 20e07be8a
Firmware Version: 01.01A01
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Sat Jan 7 16:47:49 2017 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
been run.
data collection: (11700) seconds.
Auto Offline data collection on/off supp ort.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 121) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_ FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 189 184 021 Pre-fail Always - 1533
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 15
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 65
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 11
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 3
194 Temperature_Celsius 0x0022 112 109 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error
# 1 Short offline Completed without error 00% 64 -
# 2 Short offline Completed without error 00% 63 -
# 3 Short offline Completed without error 00% 62 -
# 4 Short offline Completed without error 00% 61 -
# 5 Short offline Completed without error 00% 60 -
# 6 Short offline Completed without error 00% 59 -
# 7 Short offline Completed without error 00% 59 -
# 8 Extended offline Completed without error 00% 57 -
# 9 Extended offline Completed without error 00% 55 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ADA1 results
[root@freenas] ~# smartctl -a /dev/ada1
Device Model: WDC WD10EZEX-00WN4A0
Serial Number: WD-WCC6Y6RN037Z
LU WWN Device Id: 5 0014ee 262c6dc74
Local Time is: Sat Jan 7 16:50:38 2017 CST
was never started.
been run.
data collection: (12180) seconds.
command.
power-saving mode.
recommended polling time: ( 126) minutes.
194 Temperature_Celsius 0x0022 110 108 000 Old_age Always - 33
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
No Errors Logged
# 1 Short offline Completed without error 00% 65 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
