craftycraft
- May 28, 2013
Hi everyone,
I've spent the better part of the day reading the forum and gaining ideas for how to solve this (lots of great suggestions from cyberjock). I just built a new FreeNAS server and have been playing around with different configurations before migrating. I am having much trouble with transfer speeds on my new setup- average 4-7 MB/s transfer rate for CIFS shares over the network read and write.
Interestingly, I installed Windows 7 on this box earlier today just for fun and created a share- transfer speeds over the network were around 55 MB/s.
I am using a MSI 890GXM-G65 board, AMD FX-6100, 8GB memory (more on the way, had issues with TigerDirect order) and the onboard Realtek 8111DL.
This is my ifconfig output:
Results of dd tests:
And finally, results of iperf test from a wired Windows client:
I've tested with several cat5e and cat6 cables and haven't seen any improvement. I've also tested with different clients... I've ensured that the clients are also connected at gigabit speeds.
I am hoping someone may be able to suggest more things I can try to narrow down the source of the problem. I'm at a loss currently and am ready to begin pulling my hair out.
Thanks guys!
[root@freenas2 ~]# ifconfig
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC
        ether 6c:62:6d:38:6d:76
        inet 10.10.10.114 netmask 0xffffff00 broadcast 10.10.10.255
        media: Ethernet autoselect (1000baseT <full-duplex,master>)
        status: active
        options=3<RXCSUM,TXCSUM>
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x9
        inet6 ::1 prefixlen 128
        nd6 options=3<PERFORMNUD,ACCEPT_RTADV>  Results of dd tests:
[root@freenas2 /mnt/test]# dd if=/dev/zero of=./testfile2 bs=1m count=10k 10240+0 records in 10240+0 records out 10737418240 bytes transferred in 63.796683 secs (168306842 bytes/sec) [root@freenas2 /mnt/test]# dd if=./testfile2 of=/dev/null bs=1m 10240+0 records in 10240+0 records out 10737418240 bytes transferred in 42.458355 secs (252892941 bytes/sec)
Client connecting to 10.10.10.114, TCP port 5001 TCP window size: 0.01 MByte (default) ------------------------------------------------------------ [108] local 10.10.10.118 port 57670 connected with 10.10.10.114 port 5001 [ ID] Interval Transfer Bandwidth [108] 0.0- 1.0 sec 6.27 MBytes 52.6 Mbits/sec [108] 1.0- 2.0 sec 6.10 MBytes 51.2 Mbits/sec [108] 2.0- 3.0 sec 6.42 MBytes 53.9 Mbits/sec [108] 3.0- 4.0 sec 6.42 MBytes 53.9 Mbits/sec [108] 4.0- 5.0 sec 6.45 MBytes 54.1 Mbits/sec Done.
Thanks guys!
