Pool reconfiguration useing temp USB drives
9C1 Newbee
My goal is to reconfigure my 6x 3TB z2 into a 10x 3TB z2 pool.
However, before I can do that I need to move the data out of the pool. The current (6x 3TB) pool is 77% full. That works out to about 8TB of data.
My question is, can I create a 6x 3TB pool using USB drives to temporarily hold the data?
Or is there a better way?
9C1 Newbee
ser_rhaegar
USB drives are high risk for disaster. Not recommended.
9C1 Newbee
Thank you, guys.
Looks like I need to read up on nullfs.
Yeah.. don't do nullfs with FreeNAS. You'll be sorry. ;)
Like what has been said in the forums about a bajillion times... if you can't do it in the WebGUI you probably shouldn't be doing it...
9C1 Newbee
I wouldn't attempt it anyway. I researched a bit about it and really don't have a grasp about what it does and how it would help me attain my goal. A good bit above my skill set.
