Pool Online but Unhealthy
virusbcn
I have a RaidZ2 pool with 10 WD Red 4Tb, and its working but unhealthy, i don`t view errors in smart and "only" 3 read error in ada0 disk, Maybe it could be a random controller error? here are the output:
root@bignas:~ # zpool status -v BigNAS
pool: BigNAS
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
scan: scrub repaired 0B in 10:45:21 with 0 errors on Tue Nov 15 20:53:11 2022
NAME STATE READ WRITE CKS
BigNAS ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/723cf159-441d-11ea-8b13-d8d3855fxxxx ONLINE 3 0 0
gptid/732b9d81-441d-11ea-8b13-d8d3855fxxxx ONLINE 0 0 0
gptid/7426cb7c-441d-11ea-8b13-d8d3855fxxxx ONLINE 0 0 0
gptid/75442e2a-441d-11ea-8b13-d8d3855fxxxx ONLINE 0 0 0
gptid/765d4196-441d-11ea-8b13-d8d3855fxxxx ONLINE 0 0 0
gptid/777a427f-441d-11ea-8b13-d8d3855fxxxx ONLINE 0 0 0
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build)
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68N32N0
Serial Number: WD-WCC7K6TX17PJ
LU WWN Device Id: 5 0014ee 266f027a1
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed Nov 16 10:52:49 2022 CET
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 25) The self-test routine was aborted by
the host.
data collection: (43560) seconds.
command.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 463) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303d) SCT Status supported.
1 Raw_Read_Error_Rate 0x002f 200 184 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 158 158 021 Pre-fail Always - 7100
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 30
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 067 067 000 Old_age Always - 24545
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 30
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 21
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 57
194 Temperature_Celsius 0x0022 126 114 000 Old_age Always - 24
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Aborted by host 90% 24545 -
# 2 Short offline Completed without error 00% 24463 -
virusbcn
I try to test long smart test in ada0 but i cancel because tell me 8 hours, but conveyance test passed well, this are the last tests passed, any idea???
# 1 Conveyance offline Completed without error 00% 24548 -
# 2 Extended offline Aborted by host 90% 24545 -
# 3 Short offline Completed without error 00% 24463 -
Redcoat
virusbcn
Finally i make a zpool clear, as I read in the link it can be occasional, if it happens again then I will do a long test, the bad thing is that it says 8 hours....
Redcoat
Davvo
This mindset will make you lose your data. Forewarned is forearmed.
Also conveyance is not appropriate in this situation, as it usually verifies the mechanical parts of the hard disk to ensure that no handling damage occured. It is better than nothing, but not trustworthy enough to justify not running a long test.
