Pool offline after shucked drive back in enclosure
Yummiesttag
I have an 8TB WD elements drive that was shucked, I recently changed the computer that runs TruNAS, and I had to place the White label drive back into the enclosure. After doing so the pool shows as offline? Is there something I have to do to update the interface change?
AlexGG
The enclosure probably does sector size translation of its own. If that is the case, the drive that was formatted outside of the enclosure will not work inside the enclosure, and vice versa. You should try to connect the drive using SATA, see if it pops back up.
Yummiesttag
That makes sense. The issue will be I don’t believe the Intel NUC has SATA headers, but I’ll check. Thank you
