Pedja Ivanovic
- Oct 5, 2015
My Dell server died and I move 4 HHDs from that server to new PC, connect them, put USB Flash with TrueNAS from dead server into new PC and boot it.
Set up network and connect to TrueNAS through web interface. After logging in I get this:
I can see the HDDs
When I type zpool status -v I get this:
Can You, please, help me to activate the Pool or put HDDs in that pool or what ever I need to do to make it ONLINE and RUNNING?
Thanx a toon in forward for any suggestion.
I can see the HDDs
Last login: Wed Mar 6 12:52:16 on pts/2
FreeBSD 13.1-RELEASE-p9 n245429-296d095698e TRUENAS
TrueNAS (c) 2009-2023, iXsystems, Inc.
All rights reserved.
TrueNAS code is released under the modified BSD license with some
files copyrighted by (c) iXsystems, Inc.
For more information, documentation, help or support, go here:
http://truenas.com
Welcome to VASPKS FreeNAS server
Warning: the supported mechanisms for making configuration changes
are the TrueNAS WebUI and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
root@freenas:~ # zpool status -v
pool: freenas-boot
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: scrub repaired 0B in 00:08:18 with 11 errors on Tue Nov 28 03:53:18 2023
NAME STATE READ WRITE CKSUM
freenas-boot DEGRADED 0 0 0
da0p2 DEGRADED 0 0 0 too many errors
freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/boot/kernel-debug/t4fw_cfg.ko
freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/data/pkgdb/freenas-db
freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/usr/local/www/freenasUI/locale/ru/LC_MESSAGES/django.mo
freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/usr/local/lib/python3.7/site-packages/s3transfer/__pycache__/upload.cpython-37.pyc
freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/usr/local/lib/python3.7/site-packages/formtools/wizard/__pycache__/views.cpython-37.pyc
freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/usr/local/lib/python3.7/site-packages/botocore/data/greengrass/2017-06-07/service-2.json
freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/boot/kernel-debug/mlx4ib.ko
freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/usr/share/locale/zh_CN.UTF-8/LC_COLLATE
freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/boot/kernel-debug/smartpqi.ko
freenas-boot/ROOT/13.0-U6.1@2020-05-20-21:00:42:/usr/local/lib/migrate93/freenasUI/services/migrations/__pycache__/0067_auto__del_field_pluginsjail_jail_ip.cpython-37.pyc
root@freenas:~ #Can You, please, help me to activate the Pool or put HDDs in that pool or what ever I need to do to make it ONLINE and RUNNING?
