Pedja Ivanovic
- Oct 5, 2015
My Dell server died and I move 4 HHDs from that server to new PC, connect them, put USB Flash with TrueNAS from dead server into new PC and boot it.
Set up network and connect to TrueNAS through web interface. After logging in I get this:
I can see the HDDs
When I type zpool status -v I get this:
Can You, please, help me to activate the Pool or put HDDs in that pool or what ever I need to do to make it ONLINE and RUNNING?
Thanx a toon in forward for any suggestion.
I can see the HDDs
Last login: Wed Mar 6 12:52:16 on pts/2 FreeBSD 13.1-RELEASE-p9 n245429-296d095698e TRUENAS TrueNAS (c) 2009-2023, iXsystems, Inc. All rights reserved. TrueNAS code is released under the modified BSD license with some files copyrighted by (c) iXsystems, Inc. For more information, documentation, help or support, go here: http://truenas.com Welcome to VASPKS FreeNAS server Warning: the supported mechanisms for making configuration changes are the TrueNAS WebUI and API exclusively. ALL OTHERS ARE NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY RESULT IN SYSTEM FAILURE. root@freenas:~ # zpool status -v pool: freenas-boot state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A scan: scrub repaired 0B in 00:08:18 with 11 errors on Tue Nov 28 03:53:18 2023 config: NAME STATE READ WRITE CKSUM freenas-boot DEGRADED 0 0 0 da0p2 DEGRADED 0 0 0 too many errors errors: Permanent errors have been detected in the following files: freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/boot/kernel-debug/t4fw_cfg.ko freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/data/pkgdb/freenas-db freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/usr/local/www/freenasUI/locale/ru/LC_MESSAGES/django.mo freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/usr/local/lib/python3.7/site-packages/s3transfer/__pycache__/upload.cpython-37.pyc freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/usr/local/lib/python3.7/site-packages/formtools/wizard/__pycache__/views.cpython-37.pyc freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/usr/local/lib/python3.7/site-packages/botocore/data/greengrass/2017-06-07/service-2.json freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/boot/kernel-debug/mlx4ib.ko freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/usr/share/locale/zh_CN.UTF-8/LC_COLLATE freenas-boot/ROOT/13.0-U6.1@2020-05-12-19:57:21:/boot/kernel-debug/smartpqi.ko freenas-boot/ROOT/13.0-U6.1@2020-05-20-21:00:42:/usr/local/lib/migrate93/freenasUI/services/migrations/__pycache__/0067_auto__del_field_pluginsjail_jail_ip.cpython-37.pyc root@freenas:~ #
