Still no change.
  pool: storage-pool
 state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
        Sufficient replicas exist for the pool to continue functioning in a
        degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
        repaired.
  scan: scrub repaired 0B in 19:18:38 with 0 errors on Mon Sep 19 19:18:39 2022
        NAME                                      STATE     READ WRITE CKSUM
        storage-pool                              DEGRADED     0     0     0
          raidz2-0                                DEGRADED     0     0     0
            1766c859-9231-4127-ad35-882937845b76  ONLINE       0     0     0
            89b557d9-cc55-463c-9124-3765cff9aaac  ONLINE       0     0     0
            4a07f2eb-442c-430d-9db6-0e5fd80302a9  ONLINE       0     0     0
            c6287e21-49e0-4ffe-86a1-78a33bbbec70  ONLINE       0     0     0
            1c817e68-35de-4b8c-be59-4e98fc1fc9fe  ONLINE       0     0     0
            28dba822-3f63-4e2c-82ad-8e4467bc81a1  FAULTED     26     0     0  too many errors
        cache
          f5456732-9153-44fb-977b-fe5f1021b959    ONLINE       0     0     0Code:
[261874.964229] ata4.00: exception Emask 0x0 SAct 0x1b81000 SErr 0x0 action 0x0
[261874.972085] ata4.00: irq_stat 0x40000008
[261874.976533] ata4.00: failed command: READ FPDMA QUEUED
[261874.982197] ata4.00: cmd 60/40:98:d8:94:cb/06:00:f5:05:00/40 tag 19 ncq dma 819200 in
                         res 43/40:40:d8:94:cb/00:06:f5:05:00/40 Emask 0x409 (media error) <F>
[261874.999284] ata4.00: status: { DRDY SENSE ERR }
[261875.004335] ata4.00: error: { UNC }
[261875.052509] ata4.00: configured for UDMA/133
[261875.057606] sd 4:0:0:0: [sdd] tag#19 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=7s
[261875.067742] sd 4:0:0:0: [sdd] tag#19 Sense Key : Medium Error [current]
[261875.075302] sd 4:0:0:0: [sdd] tag#19 Add. Sense: Unrecovered read error - auto reallocate failed
[261875.084929] sd 4:0:0:0: [sdd] tag#19 CDB: Read(16) 88 00 00 00 00 05 f5 cb 94 d8 00 00 06 40 00 00
[261875.094739] blk_update_request: I/O error, dev sdd, sector 25598596312 op 0x0:(READ) flags 0x700 phys_seg 25 prio class 0
[261875.106426] zio pool=storage-pool vdev=/dev/disk/by-partuuid/28dba822-3f63-4e2c-82ad-8e4467bc81a1 error=5 type=1 offset=13104333762560 size=819200 flags=40080c80
[261875.122046] ata4: EH complete
