Pool is offline. i/o failure. don't use sata to pci 1x cards.. Drives are fine.
CookieMonster1
4x16tb drives z2.
I woke up a few days ago the pool is offline. These are data center drives really new. I have really important data such as school stuff on here and vms.
WARNING
New ZFS version or feature flags are available for pool(s) data1. Upgrading pools is a one-time process that can prevent rolling the system back to an earlier TrueNAS version. It is recommended to read the TrueNAS release notes and confirm you need the new ZFS feature flags before upgrading a pool.
2022-10-05 13:06:11 (America/Los_Angeles)
I did upgrade the pool, I thought but maybe not. Have another pool and its fine. I did only upgrade both pools at the same time before. So not sure why this poped up. Always do both. This was before the pool went offline.
When I try to create a pool I can wipe the drives. I can't do that.. I have other computers laying around so I could spin up another truenas on a older version then upgrade it the pool with the same hardware. Would that fix my problems?
This christmas I am going to try and get an offsite backup. Just don't have the money right now.
Going to run a normal smart test for long. I do read the RTFM. Hardware is not supported but I have no choice. I'm broke. The drives alone cost $1,200..
My hard drives are connect through sata to pci. 2x cards. 4x sata cables. Total of 12 drives running. Have been running for 1 year now fine.
You certainly wouldn't want to do that--either of those, really; you wouldn't want to create a pool or wipe the drives. I'm afraid I have no idea what you're quoting with the "remaining 0, lifetime 6146" stuff, or how you have "4x16tb drives z2" and "Total of 12 drives running."
I understand from your post that a pool is offline. What happens if you try to import the pool through the GUI? What do you see if you run zpool import at the CLI?
CookieMonster1
Through the gui. I can't select any drive. I tried yes and no for encryption.
Mine are encrypted.
Nothing worked.
What are the commands to import a pool. It will be about a day until I have enough time to play around with it again. Will message back when I can.
CookieMonster1
I would try and export disconnect the pool but I don't have any backups for NFS/SMB's. Would be faster if I spin up a new server and remove the drives. Have lots of shares.
I know it probably won't fix it because this is a software issue.
Davvo
If the drives are failing smart tests it's not a software issue.
HD model? Please comply with the forum rules.
joeschmuck
Old Man
So my two cents are:
1) You are not clear on describing the errors other than your pool is offline.
2) All the drive data you mentioned really is out of context. Slow down and if you desire to post the entire SMART output of all your drives, make sure you use CODE brackets, but I highly doubt your drives are the issue.
3) Have you rebooted?
4) Do you have a backup of your TrueNAS configuration file?
5) Do not upgrade your ZFS Pool !!! Not until after you recover your pool.
6) What is your boot drive? A Flash Drive, SSD, Hard Drive?
7) If you can, in the GUI, can you select the previous Boot Environment?
8) You could also try to recreate a new boot drive if you must but I'd save that for last. I dislike working with encrypted drives so you should ensure you get some good advice on this aspect.
9) Do you think you could provide some information about your system and it's setup/configuration per the forum rules? It will help us from just guessing. Computer (CPU/RAM/Boot Drive), Hard Drives, HBA if you have one.
CookieMonster1
Specs:
Dell 7010. Custom case with 12 ssd/hdd drives bays.
Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
16GB ram
2x4 TB - ST4000DM004-2CV104
4x8 TB ST8000DM004-2CX188
4x16 TB - ST16000NM000J-2TW103 Having problem with this pool. Z2.
2x120 GB dual boot ssd's - 1 is a backup.
500 Watt power supply.
As soon as I get up and running I am going to copy all my data to 4x8 TB just in case. Have 4TB of data that I really need. Years of stuff.
1) I don't know why my pool is offline. I updated my truenas to the lastest update. The pools were fine for over 2 weeks at least. Then it went offline. I am able to wipe the drives but not able to do that.
2) What is the symbol for a code brackets. Sorry.
3) I have rebooted the computer.
4) Have not upgraded my pool yet. Has been offline.
7) I am not sure. Where do I find that at?
8) I have another 7010 same as before without a custom case. I can load another truenas version of choice and try and import the pool. I don't really have the time right now but I can in the upcoming days.
I just got some time today to write this. 1 smart test has failed for long. Other 3 drives seem to be fine. Z2. Will get a replacement after I copy all the data off first to 4x8 TB ST8000DM004-2CX188.
I haven't learned any truenas command yet. So if want me to run something let me know. Thanks.
CookieMonster1
I want to say thank you for everyone that has tried to help me so far. I do really mean it!
CookieMonster1
[root@truenas[~]# smartctl -a /dev/ada6 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p1 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, [URL='http://www.smartmontools.org']www.smartmontools.org[/URL] === START OF INFORMATION SECTION === Device Model: ST16000NM000J-2TW103 Serial Number: LU WWN Device Id: 5 000c50 0dc35bde6 Firmware Version: SN02 User Capacity: 16,000,900,661,248 bytes [16.0 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-4 (minor revision not indicated) SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Oct 16 19:16:09 2022 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 559) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: (1355) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 074 064 044 Pre-fail Always - 24256947 3 Spin_Up_Time 0x0003 093 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 458 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 077 060 045 Pre-fail Always - 52607030 9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 6216 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 458 18 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 060 049 000 Old_age Always - 40 (Min/Max 35/51) 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 439 193 Load_Cycle_Count 0x0032 067 067 000 Old_age Always - 66558 194 Temperature_Celsius 0x0022 040 051 000 Old_age Always - 40 (0 22 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0023 100 100 001 Pre-fail Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 492 (18 192 0) 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 6720236852 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 204901812473 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 6214 - # 2 Extended offline Interrupted (host reset) 00% 6146 - # 3 Short offline Completed without error 00% 6142 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. root@truenas[~]# smartctl -a /dev/ada4 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p1 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, [URL='http://www.smartmontools.org']www.smartmontools.org[/URL] === START OF INFORMATION SECTION === Device Model: ST16000NM000J-2TW103 Serial Number: LU WWN Device Id: 5 000c50 0dc762c06 Firmware Version: SN02 User Capacity: 16,000,900,661,248 bytes [16.0 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-4 (minor revision not indicated) SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Oct 16 19:16:21 2022 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 567) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: (1422) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 082 064 044 Pre-fail Always - 176721801 3 Spin_Up_Time 0x0003 094 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 097 097 020 Old_age Always - 3653 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 077 060 045 Pre-fail Always - 55584096 9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 6216 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 097 097 020 Old_age Always - 3654 18 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 099 000 Old_age Always - 1 190 Airflow_Temperature_Cel 0x0022 061 052 000 Old_age Always - 39 (Min/Max 34/48) 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 3634 193 Load_Cycle_Count 0x0032 066 066 000 Old_age Always - 69709 194 Temperature_Celsius 0x0022 039 048 000 Old_age Always - 39 (0 22 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0023 100 100 001 Pre-fail Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 490 (156 195 0) 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 6720092076 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 165433952090 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 6215 - # 2 Extended offline Interrupted (host reset) 00% 6146 - # 3 Short offline Completed without error 00% 6141 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. root@truenas[~]# smartctl -a /dev/ada1 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p1 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, [URL='http://www.smartmontools.org']www.smartmontools.org[/URL] === START OF INFORMATION SECTION === Device Model: ST16000NM000J-2TW103 Serial Number: LU WWN Device Id: 5 000c50 0dc35b569 Firmware Version: SN02 User Capacity: 16,000,900,661,248 bytes [16.0 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-4 (minor revision not indicated) SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Oct 16 19:16:23 2022 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 559) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: (1375) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 080 064 044 Pre-fail Always - 96459821 3 Spin_Up_Time 0x0003 096 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 086 086 020 Old_age Always - 14987 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 073 060 045 Pre-fail Always - 20891969 9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 6213 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 086 086 020 Old_age Always - 14984 18 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 059 049 000 Old_age Always - 41 (Min/Max 40/48) 192 Power-Off_Retract_Count 0x0032 093 093 000 Old_age Always - 14964 193 Load_Cycle_Count 0x0032 060 060 000 Old_age Always - 81702 194 Temperature_Celsius 0x0022 041 049 000 Old_age Always - 41 (0 22 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0023 100 100 001 Pre-fail Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 315 (20 166 0) 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 25972827276 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 115337743932 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Interrupted (host reset) 00% 6191 - # 2 Extended offline Interrupted (host reset) 00% 6139 - # 3 Short offline Interrupted (host reset) 00% 6139 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing root@truenas[~]# smartctl -a /dev/ada8 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p1 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, [URL='http://www.smartmontools.org']www.smartmontools.org[/URL] === START OF INFORMATION SECTION === Device Model: ST16000NM000J-2TW103 Serial Number: ZR701YSW LU WWN Device Id: 5 000c50 0dc35be6d Firmware Version: SN02 User Capacity: 16,000,900,661,248 bytes [16.0 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-4 (minor revision not indicated) SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Oct 16 19:19:47 2022 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 41) The self-test routine was interrupted by the host with a hard or soft reset. Total time to complete Offline data collection: ( 559) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: (1349) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x70bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 082 064 044 Pre-fail Always - 142552571 3 Spin_Up_Time 0x0003 093 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 80 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 078 060 045 Pre-fail Always - 68662971 9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 6216 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 81 18 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 099 000 Old_age Always - 1 190 Airflow_Temperature_Cel 0x0022 059 048 000 Old_age Always - 41 (Min/Max 40/50) 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 61 193 Load_Cycle_Count 0x0032 068 068 000 Old_age Always - 65873 194 Temperature_Celsius 0x0022 041 052 000 Old_age Always - 41 (0 22 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0023 100 100 001 Pre-fail Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 539 (252 128 0) 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 6720288140 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 213626099720 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Interrupted (host reset) 00% 6195 - # 2 Extended offline Completed without error 00% 6162 - # 3 Short offline Completed without error 00% 6142 - # 4 Extended offline Interrupted (host reset) 00% 5400 - # 5 Extended offline Completed without error 00% 5183 - # 6 Extended offline Completed without error 00% 4982 - # 7 Short offline Completed without error 00% 4652 - # 8 Short offline Completed without error 00% 4651 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing]
I asked on Friday for the output of zpool import, but haven't yet seen it. Your disks are looking OK. Warmer than I'd like to see, and the lack of scheduled SMART self-tests is a concern, but neither of those would keep the pool from being available.
joeschmuck
Old Man
I agree, the disks look okay but WOW! some of them have more power cycles that hours, one significantly more. ada1 has had it's power cycled 2.4 times for each hour it's been on. Do you have an electrical problem? Connectors not fully mated? Bad connectors or maybe a bad power supply? It just strikes me as odd. ada4 and ada6 also have notable power cycle values.
Maybe i have it wrong and someone can correct me. And this may have nothing to do with your pool status.
ChrisRJ
Those power cycle counts are indeed a problem, especially since we are talking about Seagate Exos, which are data center drives. I seem to remember that someone once wrote here that those drives come with a better warranty, but are otherwise the same as other drives. No idea, whether this is correct or not. But I distinctly remember to have read in summer 2020 in a Synology support document, that automatic spin down was explicitly not supported with Exos drives, while at the same time it was for Ironwolf (Pro). I am inclined to consider this relevant.
CookieMonster1
You are making me worried about the power cycles then hours on. How do I change that? I left everything the default.
How do I do the zpool import through the terminal?
I don't really use the drives that much. Its just long term storage. Am I ruining the drives?
I will also send the other pool drives in the morning. Just in case. They all do the same thing.
joeschmuck
Old Man
Honestly I have no idea why the Power Cycles are doing that. That normally indicates the number of times that power has been applied to the drive. It has nothing to do with sleeping the drive or anything else. This is why I was suggesting for you to examine the power connectors on the drives, make sure they are fully seated. If yo have a backplane they plug into, maybe the backplane is bad. If they are plugged in okay then maybe you have a bad power supply. Or maybe the 10 hard drives and your motherboard are pulling more power than you think. A 500 Watt power supply may not be enough. This is the point where you add up all your power requirements for +5VDC and +12VDC and see if the power supply is capable of handling this current.
If the drives are spinning up and down often then yes, you are likely harming the drives in the long run but that is just my opinion.
Mine are encrypted.
Nothing worked.
Your pool was encrypted before you lost access to it?
I was in the middle of typing that I thought you were looking at the load cycle count (which is also quite high) when I took a closer look, and something that strikes me is the inconsistency here. ada6 shows a power cycle count of 458. ada4, 3654. ada1, 14,984. ada8, 81 (with a power-off retract count of only 61 somehow). All with the same power-on hours, +/- a few hours.
Um, type zpool import and press Enter?
CookieMonster1
It was unlocked. Yes they are encrypted drives. I can do a RMA for ada1, 14,984 after this is all fixed. Is it worth it? Or should I wait until the drives dies?
CookieMonster1
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY RESULT IN SYSTEM FAILURE. root@truenas[~]# zpool import pool: Rabbit2 - That's the pool, I need. id: 11485786615206464425 state: ONLINE status: One or more devices were being resilvered. action: The pool can be imported using its name or numeric identifier. config:
