I am running Truenas-12-0-u6,1
I noticed disks were disappearing off the list of drives under storage, so I replaced the power cable (powering 4 3.5 WD red)
The pool shows as offline with a red button to export/disconnect. none of the disks on the list are assigned to a pool.
Background: We recently moved and then suddenly most of the drives showed as 'degraded' so I've been slowly replacing them. I have two devs, both showing as degraded, mostly due to occasional read errors. Disks were also not showing at ALL under the disks tab, so I started replacing cables. The last one did the trick and now they are all there, but I somehow killed something.
I was sure I did a snapshot, but nothing shows there. Am I screwed?
